I read several posts on this issue, but I still don’t no how to implement this.
Is it just adding the variable in the device variables of the dashboard ?
Thanks.
Thanks.
Hello @Ronald
Are you using the Bluetooth block from balenaHub? In case you are using it, there is a Variable to use the PIN here GitHub - balena-labs-projects/bluetooth: Optimized bluetooth agent for balenaOS. Based on BlueZ 5.0.
Let us know if this works for you!
