I have the following error with the Bluetooth controller of the Intel NUC7i5BNK:
dmesg | grep "luetooth"
[ 0.415012] Bluetooth: Core ver 2.21
[ 0.415024] Bluetooth: HCI device and connection manager initialized
[ 0.415029] Bluetooth: HCI socket layer initialized
[ 0.415033] Bluetooth: L2CAP socket layer initialized
[ 0.415039] Bluetooth: SCO socket layer initialized
[ 4.567203] Bluetooth: HCI UART driver ver 2.3
[ 4.567204] Bluetooth: HCI UART protocol H4 registered
[ 4.567223] Bluetooth: HCI UART protocol Intel registered
[ 4.600608] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 4.602618] Bluetooth: hci0: Device revision is 16
[ 4.602619] Bluetooth: hci0: Secure boot is enabled
[ 4.602619] Bluetooth: hci0: OTP lock is enabled
[ 4.602620] Bluetooth: hci0: API lock is enabled
[ 4.602620] Bluetooth: hci0: Debug lock is disabled
[ 4.602621] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 4.603583] bluetooth hci0: Direct firmware load for intel/ibt-12-16.sfi failed with error -2
[ 4.603584] Bluetooth: hci0: Failed to load Intel firmware file (-2)
[ 5.508321] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.508327] Bluetooth: BNEP filters: protocol multicast
[ 5.508333] Bluetooth: BNEP socket layer initialized
[ 244.762763] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 244.763781] Bluetooth: hci0: Device revision is 16
[ 244.763784] Bluetooth: hci0: Secure boot is enabled
[ 244.763785] Bluetooth: hci0: OTP lock is enabled
[ 244.763786] Bluetooth: hci0: API lock is enabled
[ 244.763787] Bluetooth: hci0: Debug lock is disabled
[ 244.763788] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 244.763799] bluetooth hci0: Direct firmware load for intel/ibt-12-16.sfi failed with error -2
[ 244.763801] Bluetooth: hci0: Failed to load Intel firmware file (-2)
[ 1426.729257] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 1426.730262] Bluetooth: hci0: Device revision is 16
[ 1426.730265] Bluetooth: hci0: Secure boot is enabled
[ 1426.730266] Bluetooth: hci0: OTP lock is enabled
[ 1426.730268] Bluetooth: hci0: API lock is enabled
[ 1426.730269] Bluetooth: hci0: Debug lock is disabled
[ 1426.730270] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 1426.730287] bluetooth hci0: Direct firmware load for intel/ibt-12-16.sfi failed with error -2
[ 1426.730289] Bluetooth: hci0: Failed to load Intel firmware file (-2)
Looks like the Bluetooth firmware and HCI controller isn’t started.
I’m running the resin/%%RESIN_MACHINE_NAME%%-debian:jessie base image, tested also with the Stretch release: same result.
The firmware looks to be present into the /lib/firmware folder : iwlwifi-8265-22.ucode.
I see this is not the only error I have with firmware loading:
dmesg | grep "error"
[ 0.534864] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_01.bin failed with error -2
[ 4.495443] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 4.495449] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
