I want to run adxl345 accelerometer the balenaFin v1.0. I have flashed the OS and configured it using balena cli. What to do next?
We have a few example projects about working with sensors on balena that you can have a look:
- Blog posts: https://www.balena.io/blog/tag/sensors/.
- Example projects: https://github.com/balenalabs/balena-sense.
It would be great if you can share with us more about your use-case so we can help you start using balena.
