Hello resin.io team!
I’m working on a project that involves a BeagleBone Black (Rev C) and a Scanse Sweep 360 degree spinning LiDAR sensor (http://scanse.io) The device comes with a FT230X serial-to-USB based adapter (see image below and https://support.scanse.io/hc/en-us/articles/224449728-Quickstart)
If I plug in the USB end of the adapter to my Macbook, the LiDAR starts spinning, the device pops up under /dev and I can use their visualizer to look at the data coming in. However, when I plug it in my BBB’s USB port, nothing happens. The device doesn’t even get power. I posted about it on Scanse’s forums first: http://community.scanse.io/t/serial-adapter-connection/268/3 Their CEO says that the device driver should be in “newer Linux kernels”. As I mentioned in that post, the device doesn’t even show up under lsusb:
# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Moreover, if I check dmesg as I plug it into the BBB, I see:
[ 632.868038] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_bcon (89, <AValid), retry #1, port1 00000104
[ 632.923762] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (89, <AValid), retry #2, port1 00000104
[ 632.978819] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (89, <AValid), retry #3, port1 00000104
[ 633.034014] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (88, <AValid), retry #3, port1 0008010c
Other devices, such as a USB Wi-Fi adapter and a USB dongle for a wireless mouse do work on the BBB.
The BBB is running Resin OS 2.0.3+rev1 (dev) and my project is based on the resin/beaglebone-black-buildpack-deps:jessie base image. The Linux kernel version seems to be 4.4.55+. All project details are pretty much available here: https://github.com/spmaniato/resin-bbb-ros-sweep
How do I get this working on my resin-based BBB? Do I have to manually configure udev rules or something like that? If it’s not that simple, any advice on where to look next in terms of debugging?
PS1. I could forget about the USB adapter and interface directly over serial, but I’m hoping to avoid that.
PS2. I’m totally doing a writeup of this project once it’s all figured out #blog4swag
