"bash: wifi-connect: command not found" when running command from balenaCloud client terminal
I’m not able to make use of command-line arguments from the balenaCloud dashboard. When I want to update the wifi password, I see the following:
$ /usr/src/app# wifi-connect -p "test"
Should I be able to run commands from wifi-connect repo after I’ve installed it on the device via my Dockerfile?
Thank you!
@csneath I sent you a message on the wifi connect issue you opened: https://github.com/balena-io/wifi-connect/issues/259
