BalenaSound not Working on RaspberryPi 3A+
I am trying to use BalenaSound on the Rpi 3A+ but none of the images I have tried for the Rpi 3 will play audio or work (Reg/64bit OS/New images/Older images/Production/Development). I am trying to run audio through my audio interface via usb.
When I try the regular Rpi 3 images I get
exec /usr/local/bin/docker-entrypoint.sh: exec format error
When I tried the 64bit OS Rpi 3 images I get multiroom-client errors.
 multiroom-client  2023-05-16 05-50-25.716 [Error] (Controller) Error: Connection refused
 multiroom-client  2023-05-16 05-50-25.717 [Error] (Connection) Error in socket shutdown: Socket not connected
 multiroom-client  2023-05-16 05-50-26.719 [Error] (Connection) Failed to connect to host '192.168.55.135', error: Connection refused
Any help would be great.
Hi there, as a first step, maybe try disabling multi room - this can be done by setting the SOUND_MODE device variable to STANDALONE Customization | Balena Sound
Thank you for your help and for taking the the time to write a response to this post. The cause of the issue was my 18i8 Focusrite audio interface (second gen). I purchased a scarlette solo from sweetwater and everything is now running smoothly on my RPI 3A+.
For anyone who ends up here while troubleshooting, the following links helped me.
