I have done everything by the instructions online but when I switch to “audio off” and enter “hifiberry-dac” all the services (bluetooth-audio, airplay and spotify) are being killed and state exited and I have no idea why they won’t restart.
Blockquote
26.01.20 20:04:23 (+0100) bluetooth-audio Bluetooth agent registered
26.01.20 20:05:47 (+0100) Applying boot config: {“dtoverlay”:[“hifiberry-dac”],“disable_splash”:“1”,“dtparam”:[“i2c_arm=on”,“spi=on”,“audio=on”],“enable_uart”:“1”,“gpu_mem”:“16”}
26.01.20 20:05:47 (+0100) Applied boot config: {“dtoverlay”:[“hifiberry-dac”],“disable_splash”:“1”,“dtparam”:[“i2c_arm=on”,“spi=on”,“audio=on”],“enable_uart”:“1”,“gpu_mem”:“16”}
26.01.20 20:05:49 (+0100) Killing service ‘airplay sha256:5b330634160752add73ea4ea2d4aec99f51c88af3c9b12e7975c5e92f1ab3fc4’
26.01.20 20:06:12 (+0100) Killed service ‘airplay sha256:5b330634160752add73ea4ea2d4aec99f51c88af3c9b12e7975c5e92f1ab3fc4’
26.01.20 20:06:13 (+0100) Service exited ‘airplay sha256:5b330634160752add73ea4ea2d4aec99f51c88af3c9b12e7975c5e92f1ab3fc4’
26.01.20 20:06:14 (+0100) Killing service ‘bluetooth-audio sha256:bc5c5d0b8b2ed0628d947117f405816125447cbf3f5376de3fadff28178247c1’
26.01.20 20:06:29 (+0100) Killed service ‘bluetooth-audio sha256:bc5c5d0b8b2ed0628d947117f405816125447cbf3f5376de3fadff28178247c1’
26.01.20 20:06:29 (+0100) Service exited ‘bluetooth-audio sha256:bc5c5d0b8b2ed0628d947117f405816125447cbf3f5376de3fadff28178247c1’
26.01.20 20:06:29 (+0100) Killing service ‘spotify sha256:738252c4a1f3763651f5eee4fc77693a849f284c89138974282eb0ce48f3321a’
26.01.20 20:06:51 (+0100) Killed service ‘spotify sha256:738252c4a1f3763651f5eee4fc77693a849f284c89138974282eb0ce48f3321a’
26.01.20 20:06:51 (+0100) Rebooting
26.01.20 20:06:51 (+0100) Service exited ‘spotify sha256:738252c4a1f3763651f5eee4fc77693a849f284c89138974282eb0ce48f3321a’
I’d be willing to send in error logs if you let me know where I can get them from and where to send them. In addition, another issue: the logs in the little frame in the dashboard… When I clear the logs they start to reappear again and are not being refreshed. Might be related to this issue: Logs not updating in dashboard (restart needed)
When running the command for logs I get:
Blockquote
root@8dd1a74:~# journalctl -f -a -u resin-supervisor
– Logs begin at Mon 2019-12-23 09:14:37 UTC. –
Jan 26 20:49:12 8dd1a74 systemd[1]: resin-supervisor.service: Control process exited, code=exited, status=3/NOTIMPLEMENTED
Jan 26 20:49:12 8dd1a74 resin-supervisor[8316]: deactivating
Jan 26 20:49:12 8dd1a74 systemd[1]: resin-supervisor.service: Failed with result ‘timeout’.
Jan 26 20:49:12 8dd1a74 systemd[1]: Failed to start Balena supervisor.
Jan 26 20:51:45 8dd1a74 systemd[1]: resin-supervisor.service: Start-pre operation timed out. Terminating.
Jan 26 20:51:45 8dd1a74 systemd[1]: resin-supervisor.service: Control process exited, code=killed, status=15/TERM
Jan 26 20:51:45 8dd1a74 resin-supervisor[8987]: deactivating
Jan 26 20:51:45 8dd1a74 systemd[1]: resin-supervisor.service: Control process exited, code=exited, status=3/NOTIMPLEMENTED
Jan 26 20:51:45 8dd1a74 systemd[1]: resin-supervisor.service: Failed with result ‘timeout’.
Jan 26 20:51:45 8dd1a74 systemd[1]: Failed to start Balena supervisor.
Jan 26 20:54:20 8dd1a74 systemd[1]: resin-supervisor.service: Start-pre operation timed out. Terminating.
Jan 26 20:54:20 8dd1a74 systemd[1]: resin-supervisor.service: Control process exited, code=killed, status=15/TERM
Jan 26 20:54:20 8dd1a74 resin-supervisor[9511]: deactivating
Jan 26 20:54:20 8dd1a74 systemd[1]: resin-supervisor.service: Control process exited, code=exited, status=3/NOTIMPLEMENTED
Jan 26 20:54:20 8dd1a74 systemd[1]: resin-supervisor.service: Failed with result ‘timeout’.
Jan 26 20:54:20 8dd1a74 systemd[1]: Failed to start Balena supervisor.
And when I try to shutdown, I get the following error:
Request error: tunneling socket could not be established, cause=socket hang up
