and here is the dmesg log just in case anybody interested:
root@2e28e3c:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.118 (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #1 Sun Aug 16 09:58:55 UTC 2020
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 8 MiB at 0x1e400000
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] Normal zone: 1116 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x49c with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 125860
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:67:98:62 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=null rootfstype=ext4 rootwait vt.global_cursor_default=0 root=UUID=ba1eadef-ffdc-43e9-90fc-63f5549536d1 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 473468K/507904K available (8055K kernel code, 683K rwdata, 2360K rodata, 8640K init, 802K bss, 26244K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xdf800000 - 0xff800000 ( 512 MB)
lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0x(ptrval) - 0x(ptrval) (8056 kB)
.init : 0x(ptrval) - 0x(ptrval) (8640 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 684 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 803 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 28694 entries in 85 pages
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000092] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000220] bcm2835: system timer (irq = 27)
[ 0.000642] Console: colour dummy device 80x30
[ 0.000721] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060374] pid_max: default: 32768 minimum: 301
[ 0.060917] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060949] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.062389] CPU: Testing write buffer coherency: ok
[ 0.063740] Setting up static identity map for 0x8200 - 0x8238
[ 0.065173] devtmpfs: initialized
[ 0.076354] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.076778] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.076822] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.078192] pinctrl core: initialized pinctrl subsystem
[ 0.079805] NET: Registered protocol family 16
[ 0.083280] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.091086] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.091118] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.091268] Serial: AMBA PL011 UART driver
[ 0.094776] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.110700] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-06-01 13:25, variant start_cd
[ 0.120716] raspberrypi-firmware soc:firmware: Firmware hash is 6379679d1ec6a8c746d7e77e015f5b56b939976f
[ 0.174541] bcm2835-dma 20007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.177180] SCSI subsystem initialized
[ 0.177476] usbcore: registered new interface driver usbfs
[ 0.177597] usbcore: registered new interface driver hub
[ 0.177855] usbcore: registered new device driver usb
[ 0.180246] clocksource: Switched to clocksource timer
[ 0.294043] VFS: Disk quotas dquot_6.6.0
[ 0.294200] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.294519] FS-Cache: Loaded
[ 0.294869] CacheFiles: Loaded
[ 0.314608] NET: Registered protocol family 2
[ 0.315948] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.316034] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.316121] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.316223] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.316403] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.316446] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.316885] NET: Registered protocol family 1
[ 0.318014] RPC: Registered named UNIX socket transport module.
[ 0.318043] RPC: Registered udp transport module.
[ 0.318057] RPC: Registered tcp transport module.
[ 0.318070] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.476560] hw perfevents: no irqs for PMU, sampling events not supported
[ 0.476649] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.481453] Initialise system trusted keyrings
[ 0.481949] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.498166] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.498624] FS-Cache: Netfs 'nfs' registered for caching
[ 0.499996] NFS: Registering the id_resolver key type
[ 0.500064] Key type id_resolver registered
[ 0.500082] Key type id_legacy registered
[ 0.500120] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.503065] aufs 4.19.17+-20190211
[ 0.508503] Key type asymmetric registered
[ 0.508537] Asymmetric key parser 'x509' registered
[ 0.508654] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.509130] io scheduler noop registered
[ 0.509159] io scheduler deadline registered
[ 0.509840] io scheduler cfq registered (default)
[ 0.509868] io scheduler mq-deadline registered
[ 0.509885] io scheduler kyber registered
[ 0.512956] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.519045] Console: switching to colour frame buffer device 82x26
[ 0.522162] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 0.526097] bcm2835-rng 20104000.rng: hwrng registered
[ 0.526612] vc-mem: phys_addr:0x00000000 mem_base=0x1fa00000 mem_size:0x20000000(512 MiB)
[ 0.527814] vc-sm: Videocore shared memory driver
[ 0.528517] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 0.549344] brd: module loaded
[ 0.563495] loop: module loaded
[ 0.564565] zram: Added device: zram0
[ 0.565454] Loading iSCSI transport class v2.0-870.
[ 0.566326] tun: Universal TUN/TAP device driver, 1.6
[ 0.566794] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.567240] dwc_otg 20980000.usb: base=(ptrval)
[ 0.767761] Core Release: 2.80a
[ 0.767803] Setting default values for core params
[ 0.767846] Finished setting default values for core params
[ 0.968247] Using Buffer DMA mode
[ 0.968277] Periodic Transfer Interrupt Enhancement - disabled
[ 0.968291] Multiprocessor Interrupt Enhancement - disabled
[ 0.968306] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.968401] Dedicated Tx FIFOs mode
[ 0.969328] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = de514000 dma = 0x5e514000 len=9024
[ 0.969373] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.969409] dwc_otg: Microframe scheduler enabled
[ 0.969592] WARN::hcd_init_fiq:457: FIQ on core 0
[ 0.969619] WARN::hcd_init_fiq:458: FIQ ASM at c057fdd8 length 36
[ 0.969651] WARN::hcd_init_fiq:497: MPHI regs_base at df810000
[ 0.969694] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.969765] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.969847] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.969910] Init: Port Power? op_state=1
[ 0.969925] Init: Power Port (0)
[ 0.970434] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.970463] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.970482] usb usb1: Product: DWC OTG Controller
[ 0.970499] usb usb1: Manufacturer: Linux 4.19.118 dwc_otg_hcd
[ 0.970516] usb usb1: SerialNumber: 20980000.usb
[ 0.971655] hub 1-0:1.0: USB hub found
[ 0.971766] hub 1-0:1.0: 1 port detected
[ 0.972825] dwc_otg: FIQ enabled
[ 0.972836] dwc_otg: NAK holdoff enabled
[ 0.972845] dwc_otg: FIQ split-transaction FSM enabled
[ 0.972864] Module dwc_common_port init
[ 0.973435] usbcore: registered new interface driver usb-storage
[ 0.973662] usbcore: registered new interface driver usbserial_generic
[ 0.973740] usbserial: USB Serial support registered for generic
[ 0.974197] mousedev: PS/2 mouse device common for all mice
[ 0.975720] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.976180] bcm2835-cpufreq: min=700000 max=1000000
[ 0.977064] sdhci: Secure Digital Host Controller Interface driver
[ 0.977089] sdhci: Copyright(c) Pierre Ossman
[ 0.977728] mmc-bcm2835 20300000.mmcnr: could not get clk, deferring probe
[ 0.978469] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[ 0.978742] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.979411] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.979564] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.979890] usbcore: registered new interface driver usbhid
[ 0.979910] usbhid: USB HID core driver
[ 0.981201] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.983122] [vc_sm_connected_init]: start
[ 0.986916] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 0.986931] [vc_sm_connected_init]: failed to initialize shared memory service
[ 0.986971] [vc_sm_connected_init]: end - returning -1
[ 0.989682] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
[ 0.989820] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 0.990364] IPVS: ipvs loaded.
[ 0.991206] Initializing XFRM netlink socket
[ 0.992543] NET: Registered protocol family 10
[ 0.994130] Segment Routing with IPv6
[ 0.994331] NET: Registered protocol family 17
[ 0.994429] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 0.994548] Key type dns_resolver registered
[ 0.995953] registered taskstats version 1
[ 0.995987] Loading compiled-in X.509 certificates
[ 1.003295] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.003414] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.005641] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.005667] mmc-bcm2835 20300000.mmcnr: DMA channel allocated
[ 1.032793] sdhost: log_buf @ (ptrval) (5e513000)
[ 1.067150] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.068965] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.070735] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.073753] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.080379] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.102822] of_cfs_init
[ 1.103043] of_cfs_init: OK
[ 1.103794] Warning: unable to open an initial console.
[ 1.134151] Freeing unused kernel memory: 8640K
[ 1.134183] This architecture does not have kernel memory protection.
[ 1.134199] Run /init as init process
[ 1.134960] random: fast init done
[ 1.173178] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.175204] mmc0: Problem switching card into high-speed mode!
[ 1.176051] mmc0: new SDHC card at address 0001
[ 1.180071] mmcblk0: mmc0:0001 ASTC 7.45 GiB
[ 1.189161] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 1.240764] mmc1: new high speed SDIO card at address 0001
[ 2.234738] udevd[276]: Starting version 241-166-g511646b+
[ 2.247777] udevd[277]: Specified group 'render' unknown
[ 2.249431] udevd[277]: Specified group 'kvm' unknown
[ 3.014841] udevd[288]: loop1: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 3.019433] udevd[283]: loop0: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 3.024070] udevd[284]: loop2: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 3.034070] udevd[280]: loop3: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 3.039348] udevd[285]: loop4: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 3.054156] udevd[281]: loop5: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 3.059629] udevd[287]: loop6: Failed to substitute variable '$parent', ignoring: No such file or directory
[ 4.517505] zram0: detected capacity change from 0 to 125517824
[ 7.400832] udevd[283]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p2 mmcblk0' failed with exit code 1.
[ 7.406074] udevd[288]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p3 mmcblk0' failed with exit code 1.
[ 8.857857] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.859849] udevd[277]: Failed to touch /run/udev/queue: No such file or directory
[ 8.864059] udevd[277]: Failed to unlink /run/udev/queue: No such file or directory
[ 8.950493] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 9.113316] udevd: 51 output lines suppressed due to ratelimiting
[ 10.173086] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.227254] aufs au_opts_verify:1609:init[1]: dirperm1 breaks the protection by the permission bits on the lower branch
[ 10.936328] systemd[1]: System time before build time, advancing clock.
[ 12.055399] systemd[1]: /lib/systemd/system/chronyd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/chrony/chronyd.pid \xe2\x86\x92 /run/chrony/chronyd.pid; please update the unit file accordingly.
[ 12.511859] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.513804] random: systemd: uninitialized urandom read (16 bytes read)
[ 12.515944] random: systemd: uninitialized urandom read (16 bytes read)
[ 15.751590] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 18.861811] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 18.864309] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 18.864343] [vc_sm_connected_init]: start
[ 18.868601] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[ 18.868614] [vc_sm_connected_init]: failed to initialize shared memory service
[ 18.884171] media: Linux media interface: v0.10
[ 18.999557] videodev: Linux video capture interface: v2.00
[ 19.143829] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.145781] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.151657] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.219758] bcm2835_audio soc:audio: card created with 8 channels
[ 19.227067] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.237519] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 19.305594] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.316125] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 19.443442] snd-rpi-simple soc:sound: pcm5102a-hifi <-> 20203000.i2s mapping ok
[ 20.088858] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 20.203820] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 20.550621] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 20.566625] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 20.566960] usbcore: registered new interface driver brcmfmac
[ 20.814647] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 20.829074] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: May 2 2019 02:39:18 version 7.45.98.83 (r714225 CY) FWID 01-e539531f
[ 23.659585] zram: Can't change algorithm for initialized device
[ 28.051449] Adding 122572k swap on /dev/zram0. Priority:-2 extents:1 across:122572k SSFS
[ 28.288233] random: crng init done
[ 28.288264] random: 7 urandom warning(s) missed due to ratelimiting
[ 30.842015] uart-pl011 20201000.serial: no DMA platform data
[ 35.896036] Bluetooth: Core ver 2.22
[ 35.896198] NET: Registered protocol family 31
[ 35.896214] Bluetooth: HCI device and connection manager initialized
[ 35.896243] Bluetooth: HCI socket layer initialized
[ 35.896263] Bluetooth: L2CAP socket layer initialized
[ 35.896322] Bluetooth: SCO socket layer initialized
[ 35.990539] Bluetooth: HCI UART driver ver 2.3
[ 35.990567] Bluetooth: HCI UART protocol H4 registered
[ 35.990759] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 35.991078] Bluetooth: HCI UART protocol Broadcom registered
[ 39.226758] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 39.226788] Bluetooth: BNEP filters: protocol multicast
[ 39.226819] Bluetooth: BNEP socket layer initialized
[ 49.610376] i2c /dev entries driver
[ 50.737444] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 50.781817] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 50.781860] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 51.339128] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 51.339198] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 52.575803] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 54.152648] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 54.152714] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 56.920919] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 62.481266] Bridge firewalling registered
[ 65.970003] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[ 67.185683] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
[ 135.844018] IPv6: ADDRCONF(NETDEV_UP): br-a6ad853699bd: link is not ready
[ 3774.463637] br-a6ad853699bd: port 1(vethaa8e5bb) entered blocking state
[ 3774.463666] br-a6ad853699bd: port 1(vethaa8e5bb) entered disabled state
[ 3774.465720] device vethaa8e5bb entered promiscuous mode
[ 3774.528454] IPv6: ADDRCONF(NETDEV_UP): vethaa8e5bb: link is not ready
[ 3776.773185] br-a6ad853699bd: port 2(veth3d54daa) entered blocking state
[ 3776.773214] br-a6ad853699bd: port 2(veth3d54daa) entered disabled state
[ 3776.801375] device veth3d54daa entered promiscuous mode
[ 3776.810867] IPv6: ADDRCONF(NETDEV_UP): veth3d54daa: link is not ready
[ 3780.237956] br-a6ad853699bd: port 3(vethd5b6ec7) entered blocking state
[ 3780.237985] br-a6ad853699bd: port 3(vethd5b6ec7) entered disabled state
[ 3780.241123] device vethd5b6ec7 entered promiscuous mode
[ 3780.252549] IPv6: ADDRCONF(NETDEV_UP): vethd5b6ec7: link is not ready
[ 3805.219009] eth0: renamed from vethfbcd251
[ 3805.261981] IPv6: ADDRCONF(NETDEV_CHANGE): vethaa8e5bb: link becomes ready
[ 3805.262262] br-a6ad853699bd: port 1(vethaa8e5bb) entered blocking state
[ 3805.262285] br-a6ad853699bd: port 1(vethaa8e5bb) entered forwarding state
[ 3805.262625] IPv6: ADDRCONF(NETDEV_CHANGE): br-a6ad853699bd: link becomes ready
[ 3830.690035] eth0: renamed from veth725c141
[ 3830.723269] IPv6: ADDRCONF(NETDEV_CHANGE): veth3d54daa: link becomes ready
[ 3830.723561] br-a6ad853699bd: port 2(veth3d54daa) entered blocking state
[ 3830.723584] br-a6ad853699bd: port 2(veth3d54daa) entered forwarding state
[ 3840.259367] eth0: renamed from vethcc07842
[ 3840.282049] IPv6: ADDRCONF(NETDEV_CHANGE): vethd5b6ec7: link becomes ready
[ 3840.282342] br-a6ad853699bd: port 3(vethd5b6ec7) entered blocking state
[ 3840.282365] br-a6ad853699bd: port 3(vethd5b6ec7) entered forwarding state
[ 3883.731719] systemd-udevd[30]: Starting version 241
[ 3899.031327] systemd-udevd[34]: pcmC1D0p: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/pcmC1D0p/id} for writing: Permission denied
[ 3899.169414] systemd-udevd[37]: controlC1: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/controlC1/id} for writing: Permission denied
[ 3934.780230] br-a6ad853699bd: port 2(veth3d54daa) entered disabled state
[ 3934.791383] veth725c141: renamed from eth0
[ 3935.122207] br-a6ad853699bd: port 2(veth3d54daa) entered disabled state
[ 3935.155585] device veth3d54daa left promiscuous mode
[ 3935.155621] br-a6ad853699bd: port 2(veth3d54daa) entered disabled state
[ 3935.181517] br-a6ad853699bd: port 1(vethaa8e5bb) entered disabled state
[ 3935.226677] vethfbcd251: renamed from eth0
[ 3935.569149] br-a6ad853699bd: port 1(vethaa8e5bb) entered disabled state
[ 3935.625897] device vethaa8e5bb left promiscuous mode
[ 3935.625933] br-a6ad853699bd: port 1(vethaa8e5bb) entered disabled state
[35535.217593] br-a6ad853699bd: port 3(vethd5b6ec7) entered disabled state
[35535.221214] vethcc07842: renamed from eth0
[35535.444878] br-a6ad853699bd: port 3(vethd5b6ec7) entered disabled state
[35535.489609] device vethd5b6ec7 left promiscuous mode
[35535.489646] br-a6ad853699bd: port 3(vethd5b6ec7) entered disabled state
[35550.041142] br-a6ad853699bd: port 1(veth7f0ff8a) entered blocking state
[35550.041172] br-a6ad853699bd: port 1(veth7f0ff8a) entered disabled state
[35550.042022] device veth7f0ff8a entered promiscuous mode
[35550.045680] IPv6: ADDRCONF(NETDEV_UP): veth7f0ff8a: link is not ready
[35552.794781] br-a6ad853699bd: port 2(vethd334037) entered blocking state
[35552.794810] br-a6ad853699bd: port 2(vethd334037) entered disabled state
[35552.850684] device vethd334037 entered promiscuous mode
[35552.887944] IPv6: ADDRCONF(NETDEV_UP): vethd334037: link is not ready
[35553.478145] br-a6ad853699bd: port 3(veth60b965d) entered blocking state
[35553.478174] br-a6ad853699bd: port 3(veth60b965d) entered disabled state
[35553.486038] device veth60b965d entered promiscuous mode
[35553.598024] IPv6: ADDRCONF(NETDEV_UP): veth60b965d: link is not ready
[35553.598059] br-a6ad853699bd: port 3(veth60b965d) entered blocking state
[35553.598074] br-a6ad853699bd: port 3(veth60b965d) entered forwarding state
[35553.598350] br-a6ad853699bd: port 3(veth60b965d) entered disabled state
[35603.822859] eth0: renamed from veth8bb5dc5
[35603.905759] IPv6: ADDRCONF(NETDEV_CHANGE): veth7f0ff8a: link becomes ready
[35603.906040] br-a6ad853699bd: port 1(veth7f0ff8a) entered blocking state
[35603.906063] br-a6ad853699bd: port 1(veth7f0ff8a) entered forwarding state
[35632.442473] eth0: renamed from veth22dfee8
[35632.517339] IPv6: ADDRCONF(NETDEV_CHANGE): veth60b965d: link becomes ready
[35632.517632] br-a6ad853699bd: port 3(veth60b965d) entered blocking state
[35632.517654] br-a6ad853699bd: port 3(veth60b965d) entered forwarding state
[35636.546687] eth0: renamed from vetha60e573
[35636.586277] IPv6: ADDRCONF(NETDEV_CHANGE): vethd334037: link becomes ready
[35636.586572] br-a6ad853699bd: port 2(vethd334037) entered blocking state
[35636.586604] br-a6ad853699bd: port 2(vethd334037) entered forwarding state
[35649.008561] systemd-udevd[30]: Starting version 241
[35663.392503] systemd-udevd[39]: pcmC1D0p: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/pcmC1D0p/id} for writing: Permission denied
[35663.672709] systemd-udevd[34]: controlC1: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/controlC1/id} for writing: Permission denied
[35699.863016] br-a6ad853699bd: port 2(vethd334037) entered disabled state
[35699.873714] vetha60e573: renamed from eth0
[35700.102054] br-a6ad853699bd: port 2(vethd334037) entered disabled state
[35700.136658] device vethd334037 left promiscuous mode
[35700.136693] br-a6ad853699bd: port 2(vethd334037) entered disabled state
[35702.416351] br-a6ad853699bd: port 1(veth7f0ff8a) entered disabled state
[35702.452319] veth8bb5dc5: renamed from eth0
[35702.756604] br-a6ad853699bd: port 1(veth7f0ff8a) entered disabled state
[35702.778222] device veth7f0ff8a left promiscuous mode
[35702.778258] br-a6ad853699bd: port 1(veth7f0ff8a) entered disabled state
[161624.726828] br-a6ad853699bd: port 3(veth60b965d) entered disabled state
[161624.733637] veth22dfee8: renamed from eth0
[161624.942062] br-a6ad853699bd: port 3(veth60b965d) entered disabled state
[161625.006032] device veth60b965d left promiscuous mode
[161625.006069] br-a6ad853699bd: port 3(veth60b965d) entered disabled state
[161643.729272] br-a6ad853699bd: port 1(veth03241d0) entered blocking state
[161643.729300] br-a6ad853699bd: port 1(veth03241d0) entered disabled state
[161643.745303] device veth03241d0 entered promiscuous mode
[161643.759339] IPv6: ADDRCONF(NETDEV_UP): veth03241d0: link is not ready
[161644.628497] br-a6ad853699bd: port 2(veth31ffd93) entered blocking state
[161644.628526] br-a6ad853699bd: port 2(veth31ffd93) entered disabled state
[161644.629377] device veth31ffd93 entered promiscuous mode
[161644.630849] IPv6: ADDRCONF(NETDEV_UP): veth31ffd93: link is not ready
[161644.630883] br-a6ad853699bd: port 2(veth31ffd93) entered blocking state
[161644.630900] br-a6ad853699bd: port 2(veth31ffd93) entered forwarding state
[161644.631159] br-a6ad853699bd: port 2(veth31ffd93) entered disabled state
[161647.308288] br-a6ad853699bd: port 3(veth705ade3) entered blocking state
[161647.308317] br-a6ad853699bd: port 3(veth705ade3) entered disabled state
[161647.310789] device veth705ade3 entered promiscuous mode
[161647.343993] IPv6: ADDRCONF(NETDEV_UP): veth705ade3: link is not ready
[161703.610431] eth0: renamed from vetha9f7895
[161703.614438] IPv6: ADDRCONF(NETDEV_CHANGE): veth03241d0: link becomes ready
[161703.614713] br-a6ad853699bd: port 1(veth03241d0) entered blocking state
[161703.614737] br-a6ad853699bd: port 1(veth03241d0) entered forwarding state
[161708.037186] eth0: renamed from vethbd4885e
[161708.092518] IPv6: ADDRCONF(NETDEV_CHANGE): veth31ffd93: link becomes ready
[161708.092804] br-a6ad853699bd: port 2(veth31ffd93) entered blocking state
[161708.092828] br-a6ad853699bd: port 2(veth31ffd93) entered forwarding state
[161735.021202] eth0: renamed from veth2835539
[161735.105873] systemd-udevd[29]: Starting version 241
[161735.169707] IPv6: ADDRCONF(NETDEV_CHANGE): veth705ade3: link becomes ready
[161735.170020] br-a6ad853699bd: port 3(veth705ade3) entered blocking state
[161735.170043] br-a6ad853699bd: port 3(veth705ade3) entered forwarding state
[161753.934887] systemd-udevd[39]: pcmC1D0p: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/pcmC1D0p/id} for writing: Permission denied
[161754.173155] systemd-udevd[34]: controlC1: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/controlC1/id} for writing: Permission denied
[161794.258411] br-a6ad853699bd: port 3(veth705ade3) entered disabled state
[161794.267855] veth2835539: renamed from eth0
[161794.403894] br-a6ad853699bd: port 3(veth705ade3) entered disabled state
[161794.431530] device veth705ade3 left promiscuous mode
[161794.431566] br-a6ad853699bd: port 3(veth705ade3) entered disabled state
[161795.898783] br-a6ad853699bd: port 1(veth03241d0) entered disabled state
[161795.907986] vetha9f7895: renamed from eth0
[161796.431294] br-a6ad853699bd: port 1(veth03241d0) entered disabled state
[161796.461488] device veth03241d0 left promiscuous mode
[161796.461547] br-a6ad853699bd: port 1(veth03241d0) entered disabled state
[166837.370428] br-a6ad853699bd: port 2(veth31ffd93) entered disabled state
[166837.380633] vethbd4885e: renamed from eth0
[166837.598149] br-a6ad853699bd: port 2(veth31ffd93) entered disabled state
[166837.640160] device veth31ffd93 left promiscuous mode
[166837.640196] br-a6ad853699bd: port 2(veth31ffd93) entered disabled state
[166848.709811] br-a6ad853699bd: port 1(vethc4caa54) entered blocking state
[166848.709840] br-a6ad853699bd: port 1(vethc4caa54) entered disabled state
[166848.731102] device vethc4caa54 entered promiscuous mode
[166848.769434] IPv6: ADDRCONF(NETDEV_UP): vethc4caa54: link is not ready
[166850.797715] br-a6ad853699bd: port 2(veth8b0cf81) entered blocking state
[166850.797745] br-a6ad853699bd: port 2(veth8b0cf81) entered disabled state
[166850.806917] device veth8b0cf81 entered promiscuous mode
[166850.835991] IPv6: ADDRCONF(NETDEV_UP): veth8b0cf81: link is not ready
[166851.675328] br-a6ad853699bd: port 3(vethb7aa981) entered blocking state
[166851.675357] br-a6ad853699bd: port 3(vethb7aa981) entered disabled state
[166851.676348] device vethb7aa981 entered promiscuous mode
[166851.687183] IPv6: ADDRCONF(NETDEV_UP): vethb7aa981: link is not ready
[166851.687265] br-a6ad853699bd: port 3(vethb7aa981) entered blocking state
[166851.687281] br-a6ad853699bd: port 3(vethb7aa981) entered forwarding state
[166851.687539] br-a6ad853699bd: port 3(vethb7aa981) entered disabled state
[166899.732588] eth0: renamed from vethe9434d9
[166899.777509] IPv6: ADDRCONF(NETDEV_CHANGE): vethc4caa54: link becomes ready
[166899.777799] br-a6ad853699bd: port 1(vethc4caa54) entered blocking state
[166899.777821] br-a6ad853699bd: port 1(vethc4caa54) entered forwarding state
[166932.079562] eth0: renamed from vethfd6043f
[166932.172993] IPv6: ADDRCONF(NETDEV_CHANGE): vethb7aa981: link becomes ready
[166932.173289] br-a6ad853699bd: port 3(vethb7aa981) entered blocking state
[166932.173310] br-a6ad853699bd: port 3(vethb7aa981) entered forwarding state
[166936.443486] eth0: renamed from vethffdc430
[166936.471858] IPv6: ADDRCONF(NETDEV_CHANGE): veth8b0cf81: link becomes ready
[166936.472227] br-a6ad853699bd: port 2(veth8b0cf81) entered blocking state
[166936.472261] br-a6ad853699bd: port 2(veth8b0cf81) entered forwarding state
[166954.532805] systemd-udevd[29]: Starting version 241
[166973.251278] systemd-udevd[35]: pcmC1D0p: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/pcmC1D0p/id} for writing: Permission denied
[166973.456722] systemd-udevd[38]: controlC1: Failed to open ATTR{/sys/devices/platform/soc/soc:sound/sound/card1/controlC1/id} for writing: Permission denied
[167038.340097] br-a6ad853699bd: port 1(vethc4caa54) entered disabled state
[167038.359452] vethe9434d9: renamed from eth0
[167038.418761] br-a6ad853699bd: port 2(veth8b0cf81) entered disabled state
[167038.425063] vethffdc430: renamed from eth0
[167038.637786] br-a6ad853699bd: port 1(vethc4caa54) entered disabled state
[167038.664477] device vethc4caa54 left promiscuous mode
[167038.664514] br-a6ad853699bd: port 1(vethc4caa54) entered disabled state
[167038.691033] br-a6ad853699bd: port 2(veth8b0cf81) entered disabled state
[167038.722570] device veth8b0cf81 left promiscuous mode
[167038.722606] br-a6ad853699bd: port 2(veth8b0cf81) entered disabled state
root@2e28e3c:~#
