Hi klutchell
My logs are theese:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 4.19.75 (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #1 SMP PREEMPT Tue May 26 11:06:42 UTC 2020
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 2074112
[ 0.000000] DMA32 zone: 4096 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 255488 pages, LIFO batch:63
[ 0.000000] Normal zone: 28672 pages used for memmap
[ 0.000000] Normal zone: 1818624 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xa0/0x464 with crng_init=0
[ 0.000000] percpu: Embedded 24 pages/cpu s57880 r8192 d32232 u98304
[ 0.000000] pcpu-alloc: s57880 r8192 d32232 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for EL2 vector hardening
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2041344
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M smsc95xx.macaddr=DC:A6:32:B4:CE:AA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 dwc_otg.lpm_enable=0 console=tty1 console=ttyS0,115200 rootfstype=ext4 rootwait root=UUID=ba1eadef-d225-4e15-be2f-66aa14785412 rootwait
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x3a5ff000-0x3e5ff000] (64MB)
[ 0.000000] Memory: 7799376K/8296448K available (9020K kernel code, 1064K rwdata, 2928K rodata, 10496K init, 1127K bss, 234928K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32052 entries in 126 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000213] Console: colour dummy device 80x25
[ 0.000556] console [tty1] enabled
[ 0.000609] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000647] pid_max: default: 32768 minimum: 301
[ 0.000968] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.001057] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.024038] ASID allocator initialised with 32768 entries
[ 0.032039] rcu: Hierarchical SRCU implementation.
[ 0.040541] EFI services will not be available.
[ 0.048098] smp: Bringing up secondary CPUs ...
[ 0.080290] Detected PIPT I-cache on CPU1
[ 0.080350] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.112386] Detected PIPT I-cache on CPU2
[ 0.112430] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.144506] Detected PIPT I-cache on CPU3
[ 0.144548] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.144689] smp: Brought up 1 node, 4 CPUs
[ 0.144776] SMP: Total of 4 processors activated.
[ 0.144798] CPU features: detected: 32-bit EL0 Support
[ 0.145451] CPU: All CPU(s) started at EL2
[ 0.145502] alternatives: patching kernel code
[ 0.146647] devtmpfs: initialized
[ 0.154679] Enabled cp15_barrier support
[ 0.154725] Enabled setend support
[ 0.155091] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.155133] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.161574] pinctrl core: initialized pinctrl subsystem
[ 0.162188] DMI not present or invalid.
[ 0.162593] NET: Registered protocol family 16
[ 0.163820] cpuidle: using governor menu
[ 0.164142] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.164171] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.166524] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.166629] Serial: AMBA PL011 UART driver
[ 0.169946] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.202002] bcm2835-dma fe007000.dma: DMA legacy API manager at (____ptrval____), dmachans=0x1
[ 0.204258] vgaarb: loaded
[ 0.204587] SCSI subsystem initialized
[ 0.204970] usbcore: registered new interface driver usbfs
[ 0.205034] usbcore: registered new interface driver hub
[ 0.205146] usbcore: registered new device driver usb
[ 0.205241] pps_core: LinuxPPS API ver. 1 registered
[ 0.205262] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.205298] PTP clock support registered
[ 0.213009] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-20 16:41, variant start_cd
[ 0.216780] raspberrypi-firmware soc:firmware: Firmware hash is 00f355997ccdacfaac70e6e07803eccc0a6f1d6e
[ 0.222071] clocksource: Switched to clocksource arch_sys_counter
[ 0.297408] VFS: Disk quotas dquot_6.6.0
[ 0.297516] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.297716] FS-Cache: Loaded
[ 0.297902] CacheFiles: Loaded
[ 0.298510] simple-framebuffer: probe of 0.framebuffer failed with error -12
[ 0.306246] NET: Registered protocol family 2
[ 0.306923] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.307005] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.307394] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.308426] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.308653] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.308757] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.309099] NET: Registered protocol family 1
[ 0.313804] RPC: Registered named UNIX socket transport module.
[ 0.313829] RPC: Registered udp transport module.
[ 0.313848] RPC: Registered tcp transport module.
[ 0.313866] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.313893] PCI: CLS 0 bytes, default 64
[ 0.380810] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.382761] Initialise system trusted keyrings
[ 0.383017] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.390279] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.390501] FS-Cache: Netfs 'nfs' registered for caching
[ 0.391192] NFS: Registering the id_resolver key type
[ 0.391239] Key type id_resolver registered
[ 0.391258] Key type id_legacy registered
[ 0.391285] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.393984] Key type asymmetric registered
[ 0.394011] Asymmetric key parser 'x509' registered
[ 0.394110] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.394304] io scheduler noop registered
[ 0.394327] io scheduler deadline registered
[ 0.394484] io scheduler cfq registered (default)
[ 0.394507] io scheduler mq-deadline registered
[ 0.394526] io scheduler kyber registered
[ 0.419515] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.419567] brcm-pcie fd500000.pcie: could not get clock
[ 0.419651] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.419707] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.494111] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.494432] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.494463] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.494489] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.494555] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.494709] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.497792] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.497919] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.498316] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.501209] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.501245] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.501330] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.501358] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.501465] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.501528] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 20.977010] pci 0000:01:00.0: xHCI HW not ready after 5 sec (HC bug?) status = 0x801
[ 20.977092] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x888 took 19995752 usecs
[ 20.978991] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 20.981010] iproc-rng200 fe104000.rng: hwrng registered
[ 20.981322] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 20.982025] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 20.982424] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 20.991868] brd: module loaded
[ 21.001645] loop: module loaded
[ 21.002551] Loading iSCSI transport class v2.0-870.
[ 21.004313] libphy: Fixed MDIO Bus: probed
[ 21.004361] tun: Universal TUN/TAP device driver, 1.6
[ 21.004963] bcmgenet fd580000.genet: failed to get enet clock
[ 21.004994] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 21.005021] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 21.005048] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 21.005081] bcmgenet: Skipping UMAC reset
[ 21.005329] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 21.014105] libphy: bcmgenet MII bus: probed
[ 21.046705] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(____ptrval____)
[ 21.047978] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 21.048021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 21.548112] xhci_hcd 0000:01:00.0: can't setup: -110
[ 21.548142] xhci_hcd 0000:01:00.0: USB bus 1 deregistered
[ 21.548216] xhci_hcd 0000:01:00.0: init 0000:01:00.0 fail, -110
[ 21.548260] xhci_hcd: probe of 0000:01:00.0 failed with error -110
[ 21.548651] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 21.548896] dwc_otg fe980000.usb: base=(____ptrval____)
[ 21.751238] Core Release: 2.80a
[ 21.751260] Setting default values for core params
[ 21.751295] Finished setting default values for core params
[ 21.953797] Using Buffer DMA mode
[ 21.953819] Periodic Transfer Interrupt Enhancement - disabled
[ 21.953838] Multiprocessor Interrupt Enhancement - disabled
[ 21.953858] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 21.953878] Dedicated Tx FIFOs mode
[ 21.954387] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ffffff800bbcc000 dma = 0x00000000ded04000 len=9024
[ 21.954436] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 21.954485] dwc_otg: Microframe scheduler enabled
[ 21.954614] WARN::hcd_init_fiq:497: MPHI regs_base at ffffff800989d200
[ 21.954703] dwc_otg fe980000.usb: DWC OTG Controller
[ 21.954738] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 1
[ 21.954790] dwc_otg fe980000.usb: irq 25, io mem 0x00000000
[ 21.954851] Init: Port Power? op_state=1
[ 21.954868] Init: Power Port (0)
[ 21.955149] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 21.955179] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 21.955204] usb usb1: Product: DWC OTG Controller
[ 21.955225] usb usb1: Manufacturer: Linux 4.19.75 dwc_otg_hcd
[ 21.955246] usb usb1: SerialNumber: fe980000.usb
[ 21.955798] hub 1-0:1.0: USB hub found
[ 21.955862] hub 1-0:1.0: 1 port detected
[ 21.956477] dwc_otg: FIQ enabled
[ 21.956486] dwc_otg: NAK holdoff enabled
[ 21.956494] dwc_otg: FIQ split-transaction FSM enabled
[ 21.956506] Module dwc_common_port init
[ 21.956746] usbcore: registered new interface driver uas
[ 21.956831] usbcore: registered new interface driver usb-storage
[ 21.957011] mousedev: PS/2 mouse device common for all mice
[ 21.958709] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 21.958896] bcm2835-cpufreq: min=600000 max=1500000
[ 21.959511] sdhci: Secure Digital Host Controller Interface driver
[ 21.959534] sdhci: Copyright(c) Pierre Ossman
[ 21.959934] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 21.960339] sdhci-pltfm: SDHCI platform and OF driver helper
[ 21.964475] ledtrig-cpu: registered to indicate activity on CPUs
[ 21.964546] hidraw: raw HID events driver (C) Jiri Kosina
[ 21.964609] usbcore: registered new interface driver usbhid
[ 21.964618] usbhid: USB HID core driver
[ 21.965032] vchiq: vchiq_init_state: slot_zero = (____ptrval____), is_master = 0
[ 21.967507] Initializing XFRM netlink socket
[ 21.967794] NET: Registered protocol family 10
[ 21.968377] Segment Routing with IPv6
[ 21.968433] NET: Registered protocol family 17
[ 21.968461] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 21.968517] Key type dns_resolver registered
[ 21.968917] registered taskstats version 1
[ 21.968934] Loading compiled-in X.509 certificates
[ 21.972183] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 21.972241] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 21.974520] console [ttyS0] disabled
[ 21.974544] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 22, base_baud = 62500000) is a 16550
[ 23.175662] console [ttyS0] enabled
[ 23.179437] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 23.187363] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 23.195334] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 23.201441] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 23.231255] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 23.256454] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 23.263702] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 23.270805] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 23.276389] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 23.284890] of_cfs_init
[ 23.287436] of_cfs_init: OK
[ 23.300731] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 23.306394] Freeing unused kernel memory: 10496K
[ 23.307973] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 23.311147] Run /init as init process
[ 23.363916] random: fast init done
[ 23.386421] mmc1: new high speed SDIO card at address 0001
[ 23.417788] mmc0: new ultra high speed DDR50 SDXC card at address e624
[ 23.425527] mmcblk0: mmc0:e624 AFGCE 59.5 GiB
[ 23.437874] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 24.707594] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 24.740929] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 25.009301] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 25.229263] systemd[1]: System time before build time, advancing clock.
[ 25.337335] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 25.355308] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 25.453414] systemd[1]: /lib/systemd/system/chronyd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/chrony/chronyd.pid \xe2\x86\x92 /run/chrony/chronyd.pid; please update the unit file accordingly.
[ 25.536617] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.562280] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.586170] random: systemd: uninitialized urandom read (16 bytes read)
[ 26.945714] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 28.059668] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 28.071286] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 28.087666] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 28.102363] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 28.123265] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 28.135154] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 28.148785] media: Linux media interface: v0.10
[ 28.155202] [vc_sm_connected_init]: start
[ 28.192138] videodev: Linux video capture interface: v2.00
[ 28.197868] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[ 28.197876] [vc_sm_connected_init]: failed to initialize shared memory service
[ 28.232715] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 28.250566] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 28.260295] bcm2835_audio soc:audio: card created with 8 channels
[ 28.299306] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 28.306284] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 28.309792] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 28.332735] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 28.342679] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 28.350659] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 28.359155] [drm] No driver support for vblank timestamp query.
[ 28.365959] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 28.377585] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 28.396084] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 28.409973] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 28.430705] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 28.447850] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 28.494803] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 28.581161] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 28.587022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 28.598286] usbcore: registered new interface driver brcmfmac
[ 28.819954] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 28.840982] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: May 2 2019 02:46:17 version 7.45.189 (r714228 CY) FWID 01-e1db26e2
[ 29.240759] uart-pl011 fe201000.serial: no DMA platform data
[ 30.554330] random: crng init done
[ 30.557802] random: 7 urandom warning(s) missed due to ratelimiting
[ 31.178941] i2c /dev entries driver
[ 31.246023] brcmfmac: power management disabled
[ 31.618316] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.630267] bcmgenet: Skipping UMAC reset
[ 31.710367] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 31.723613] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.767857] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 31.807674] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 31.813867] brcmfmac: power management disabled
[ 32.357053] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 32.363151] brcmfmac: power management disabled
[ 32.540036] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 32.734215] bcmgenet fd580000.genet eth0: Link is Down
[ 34.187785] Bridge firewalling registered
[ 34.552486] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
[ 34.700238] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[ 34.866063] IPv6: ADDRCONF(NETDEV_UP): br-e27a6943e73a: link is not ready
[ 35.734056] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 35.740133] brcmfmac: power management disabled
[ 35.887956] Bluetooth: Core ver 2.22
[ 35.891657] NET: Registered protocol family 31
[ 35.896203] Bluetooth: HCI device and connection manager initialized
[ 35.902704] Bluetooth: HCI socket layer initialized
[ 35.907673] Bluetooth: L2CAP socket layer initialized
[ 35.913064] Bluetooth: SCO socket layer initialized
[ 35.964607] Bluetooth: HCI UART driver ver 2.3
[ 35.969232] Bluetooth: HCI UART protocol H4 registered
[ 35.974702] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 35.981660] Bluetooth: HCI UART protocol Broadcom registered
[ 36.128384] br-e27a6943e73a: port 1(veth2d0b18b) entered blocking state
[ 36.135385] br-e27a6943e73a: port 1(veth2d0b18b) entered disabled state
[ 36.144459] device veth2d0b18b entered promiscuous mode
[ 36.151685] IPv6: ADDRCONF(NETDEV_UP): veth2d0b18b: link is not ready
[ 36.158422] br-e27a6943e73a: port 1(veth2d0b18b) entered blocking state
[ 36.165177] br-e27a6943e73a: port 1(veth2d0b18b) entered forwarding state
[ 36.183037] br-e27a6943e73a: port 1(veth2d0b18b) entered disabled state
[ 36.344244] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.349882] Bluetooth: BNEP filters: protocol multicast
[ 36.355432] Bluetooth: BNEP socket layer initialized
[ 36.629284] br-e27a6943e73a: port 2(veth2d5601c) entered blocking state
[ 36.636099] br-e27a6943e73a: port 2(veth2d5601c) entered disabled state
[ 36.643769] device veth2d5601c entered promiscuous mode
[ 36.649696] IPv6: ADDRCONF(NETDEV_UP): veth2d5601c: link is not ready
[ 36.656482] br-e27a6943e73a: port 2(veth2d5601c) entered blocking state
[ 36.663246] br-e27a6943e73a: port 2(veth2d5601c) entered forwarding state
[ 36.670522] IPv6: ADDRCONF(NETDEV_CHANGE): br-e27a6943e73a: link becomes ready
[ 36.678297] br-e27a6943e73a: port 2(veth2d5601c) entered disabled state
[ 36.778971] br-e27a6943e73a: port 3(veth6fe1e03) entered blocking state
[ 36.787052] br-e27a6943e73a: port 3(veth6fe1e03) entered disabled state
[ 36.794038] device veth6fe1e03 entered promiscuous mode
[ 36.801497] IPv6: ADDRCONF(NETDEV_UP): veth6fe1e03: link is not ready
[ 36.810113] br-e27a6943e73a: port 3(veth6fe1e03) entered blocking state
[ 36.816896] br-e27a6943e73a: port 3(veth6fe1e03) entered forwarding state
[ 36.826406] br-e27a6943e73a: port 3(veth6fe1e03) entered disabled state
[ 39.376593] systemd-udevd[28]: Starting version 241
[ 39.491278] eth0: renamed from veth6545f0d
[ 39.532508] IPv6: ADDRCONF(NETDEV_CHANGE): veth2d0b18b: link becomes ready
[ 39.540794] br-e27a6943e73a: port 1(veth2d0b18b) entered blocking state
[ 39.547565] br-e27a6943e73a: port 1(veth2d0b18b) entered forwarding state
[ 39.662347] systemd-udevd[29]: Starting version 241
[ 40.200788] eth0: renamed from vethe689aae
[ 40.291550] eth0: renamed from veth76ac246
[ 40.368229] IPv6: ADDRCONF(NETDEV_CHANGE): veth6fe1e03: link becomes ready
[ 40.375419] br-e27a6943e73a: port 3(veth6fe1e03) entered blocking state
[ 40.382234] br-e27a6943e73a: port 3(veth6fe1e03) entered forwarding state
[ 40.386794] IPv6: ADDRCONF(NETDEV_CHANGE): veth2d5601c: link becomes ready
[ 40.400681] br-e27a6943e73a: port 2(veth2d5601c) entered blocking state
[ 40.407458] br-e27a6943e73a: port 2(veth2d5601c) entered forwarding state
[ 41.043159] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 43.820487] udevd[193]: starting version 3.2.9
[ 43.966043] systemd-udevd[30]: Starting version 245.6-2
[ 44.066561] udevd[194]: starting eudev-3.2.9
[ 45.606186] systemd-udevd[42]: console: Failed to process device, ignoring: File exists
[ 45.613447] systemd-udevd[52]: ptmx: Failed to process device, ignoring: File exists
[ 46.882923] systemd-udevd[46]: ptmx: Failed to process device, ignoring: File exists
[ 46.883605] systemd-udevd[39]: console: Failed to process device, ignoring: File exists
[ 51.541091] br-e27a6943e73a: port 4(vethdf21c80) entered blocking state
[ 51.549338] br-e27a6943e73a: port 4(vethdf21c80) entered disabled state
[ 51.556368] device vethdf21c80 entered promiscuous mode
[ 51.571660] IPv6: ADDRCONF(NETDEV_UP): vethdf21c80: link is not ready
[ 51.717847] br-e27a6943e73a: port 5(veth410d48d) entered blocking state
[ 51.737589] br-e27a6943e73a: port 5(veth410d48d) entered disabled state
[ 51.745313] device veth410d48d entered promiscuous mode
[ 51.755869] IPv6: ADDRCONF(NETDEV_UP): veth410d48d: link is not ready
[ 51.762547] br-e27a6943e73a: port 5(veth410d48d) entered blocking state
[ 51.769318] br-e27a6943e73a: port 5(veth410d48d) entered forwarding state
[ 52.234029] br-e27a6943e73a: port 6(vethf9230da) entered blocking state
[ 52.241592] br-e27a6943e73a: port 6(vethf9230da) entered disabled state
[ 52.248559] device vethf9230da entered promiscuous mode
[ 52.256412] IPv6: ADDRCONF(NETDEV_UP): vethf9230da: link is not ready
[ 52.270890] br-e27a6943e73a: port 6(vethf9230da) entered blocking state
[ 52.277651] br-e27a6943e73a: port 6(vethf9230da) entered forwarding state
[ 52.543228] br-e27a6943e73a: port 5(veth410d48d) entered disabled state
[ 52.550371] br-e27a6943e73a: port 6(vethf9230da) entered disabled state
[ 55.418253] eth0: renamed from veth5eff244
[ 55.467223] IPv6: ADDRCONF(NETDEV_CHANGE): vethdf21c80: link becomes ready
[ 55.474576] br-e27a6943e73a: port 4(vethdf21c80) entered blocking state
[ 55.481359] br-e27a6943e73a: port 4(vethdf21c80) entered forwarding state
[ 55.582067] br-e27a6943e73a: port 2(veth2d5601c) entered disabled state
[ 55.594953] veth76ac246: renamed from eth0
[ 55.694619] br-e27a6943e73a: port 2(veth2d5601c) entered disabled state
[ 55.787604] device veth2d5601c left promiscuous mode
[ 55.795288] br-e27a6943e73a: port 2(veth2d5601c) entered disabled state
[ 55.860924] eth0: renamed from veth87da0d8
[ 55.886730] IPv6: ADDRCONF(NETDEV_CHANGE): veth410d48d: link becomes ready
[ 55.894042] br-e27a6943e73a: port 5(veth410d48d) entered blocking state
[ 55.900797] br-e27a6943e73a: port 5(veth410d48d) entered forwarding state
[ 56.429504] br-e27a6943e73a: port 2(veth783616b) entered blocking state
[ 56.455711] br-e27a6943e73a: port 2(veth783616b) entered disabled state
[ 56.464401] device veth783616b entered promiscuous mode
[ 56.471354] IPv6: ADDRCONF(NETDEV_UP): veth783616b: link is not ready
[ 57.295726] eth0: renamed from vethf6548b3
[ 57.341620] IPv6: ADDRCONF(NETDEV_CHANGE): vethf9230da: link becomes ready
[ 57.348888] br-e27a6943e73a: port 6(vethf9230da) entered blocking state
[ 57.355667] br-e27a6943e73a: port 6(vethf9230da) entered forwarding state
[ 59.852213] Bluetooth: RFCOMM TTY layer initialized
[ 59.857326] Bluetooth: RFCOMM socket layer initialized
[ 59.863898] Bluetooth: RFCOMM ver 1.11
[ 60.078598] eth0: renamed from vethc646b57
[ 60.119320] IPv6: ADDRCONF(NETDEV_CHANGE): veth783616b: link becomes ready
[ 60.126583] br-e27a6943e73a: port 2(veth783616b) entered blocking state
[ 60.133330] br-e27a6943e73a: port 2(veth783616b) entered forwarding state
thank you for your help
