@dirk When you ran this, did you have to add any Account SID or Auth Tokens. I’ve flashed a new image on my BalenaFin board in a new application and attached an antenna to it. I added a Twilio Sim chip and tried to connect to it. The outputs below are for mmcli -m 0 and ModemManager
mmcli -m 0 output:
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-pin2 (10), sim-puk (10), sim-puk2 (10)
| state: connecting
| power state: on
| access tech: lte
| signal quality: 76% (recent)
Modem Manager logs:
Jun 11 01:56:30 30cf246 ModemManager[686]: Simple connect started…
Jun 11 01:56:30 30cf246 ModemManager[686]: Simple connect state (4/8): Wait to get fully enabled
Jun 11 01:56:30 30cf246 ModemManager[686]: Simple connect state (5/8): Register
Jun 11 01:56:30 30cf246 ModemManager[686]: Simple connect state (6/8): Bearer
Jun 11 01:56:30 30cf246 ModemManager[686]: Simple connect state (7/8): Connect
Jun 11 01:56:30 30cf246 ModemManager[686]: Modem /org/freedesktop/ModemManager1/Modem/0: state changed (registered → connecting)
Jun 11 01:56:31 30cf246 ModemManager[686]: error: couldn’t start network: QMI protocol error (14): ‘CallFailed’
Jun 11 01:56:31 30cf246 ModemManager[686]: call end reason (1): ‘generic-unspecified’
Jun 11 01:56:31 30cf246 ModemManager[686]: verbose call end reason (2,208): [internal] pdn-ipv4-call-disallowed
Jun 11 01:56:31 30cf246 ModemManager[686]: Modem /org/freedesktop/ModemManager1/Modem/0: state changed (connecting → registered)
It looks like it’s trying to connect to the network, but it’s failing for some reason. I noticed on my Twilio account, there’s an Account SID and an Auth Token. I wasn’t sure if I had to add that to my file and if I do, where do I put it?
