Hello!
Ive set up my balena sound with ethernet connection. Now I want to add a wifi network so that when I dont have an ethernet cable left I can use my wifi. Which command do I need for adding a wifi network?
Hello!
Hi there,
unfortunately we don’t have any direct commands to achieve this at the moment.
To add a WiFi network to your device, please have a look here: https://www.balena.io/docs/reference/OS/network/2.x/#changing-the-network-at-runtime
We highly recommend taking a look at the project listed in the documentation called wifi-connect
Otherwise manually speaking, just add the configuration file that you find in the documentation https://www.balena.io/docs/reference/OS/network/2.x/#wifi-setup, in one of the two directories:
/mnt/boot/system-connections/ (can only be changed manually)/etc/NetworkManager/system-connections/ (can be edited either manually or via NM API)(manual changes are applied only after device reboot)
We recommend NOT adding the config file in both directories as the file in /mnt/boot/system-connections/ would overwrite the file with the same name found in /etc/NetworkManager/system-connections/ at each reboot.
Manual example:
from the dashboard > device page (HOST OS terminal) we run these two commands:
cd /mnt/boot/system-connection (hypothetical chosen location)
cat <<EOT >> resin-wifi
[connection]
id=balena-wifi
type=wifi
[wifi]
hidden=true
mode=infrastructure
ssid=My Awesome WiFi Ssid
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=super_secret_wifi_password
EOT
(hypothetical Netwrok configuration)
Hi @hanno.lk,
a colleague pointed out to me that I previously forgot to mention nmcli that can also be used to create a connection profile, instead of editing or creating a text file.
Here you can find a some examples: https://developer.gnome.org/NetworkManager/stable/nmcli-examples.html
