I have a BalenaOS device running and connected to BalenaCloud via a Wifi interface.
I need also my device to be connected to another local network via another Ethernet interface. But I forgot to do the setup before flashing the OS (with this documentation: https://www.balena.io/docs/reference/OS/network/2.x/#setting-a-static-ip)
How can I add new Ethernet settings in a running device ? I’ve tried to create a new file in system-connection but the file system is in read-only so I cannot create it.
I read about is interacting with the NetworkManager via its DBUS API (https://www.balena.io/docs/reference/OS/network/2.x/#changing-the-network-at-runtime) but I’m not sure if this solution applies to me since I want to do it directly from the HostOS (not from a container), and with Ethernet (not Wifi). I haven’t tried because changing network configuration can be dangerous and I don’t want to “lose” my device.
Thanks for helping me
