Oh my god same! My usb drive broke after using Etcher…I’ve flashed it many times with rufus and it still working, but not with etcher in this case bc my usb has light on it so if it’s connected it will light up and blink and when I connected to my laptop it just lights up, no blink and no pop up on windows, it popped up on BIOS but with different name “ChipFish BlnkDisk” iirc. It wasn’t detected in any device I tried.
I threw my usb away and will get a new and I will never touch this faulty app again.
Seriously fix your app, developers!
I solved this problem by installing a program in windows called “mini tool partition wizard free” and resetting completely the USB drive by recompiling his sectors with 0 or 1 (there’s an option called like that when you reset it),it worked for me and restored the usb drive.
Hope may help by figure it out
Note: In the following, the # in the sample commands is the terminal prompt. Yours may be different. Don’t type that.
And the [n] is a number that depends on your configuration. Type the appropriate number not literal [n].
I found this somewhere, but now can’t figure out where, but this worked just fine in a Mac. Just be really, really careful, since this could easily trash your system.
First, you need to be sure which disk you’re fixing. So with the disk not installed, type:
#diskutil list
That will give a list of details of each current disk, as /dev/disk0, /dev/disk1, etc.
In my experience, /dev/disk0 is an internal recovery disk and /dev/disk1 is your internal drive. You may have others.
Then insert your broken USB drive and run
#diskutil list
again. Your usb drive should now appear as an additional /dev/disk[n].
Now you’re going to zap that new /dev/disk[n]. Be very careful here. I take no responsibility if you end up killing your system, but this worked for me. The command is:
#diskutil eraseDisk FAT32 UNTITLED MBRFormat /dev/disk[n]
(Where [n] is the drive you’re recovering. And UNTITLED is just a name for the recovered disk.) #diskutil list
And that should show your USB drive as now an actual drive, and you can then use the standard Mac DiskUtils app to reformat the drive as you want.
Hey, so for anyone this might help: I am on a Mac (iMac M4 desktop), and I was able to pull my 500gb mini SD card out of this “corrupted” state by using a program called SD Card Formatter. Every other way I have personally tried (such as Disk Utility, using Windows, using other programs on Windows, etc.) claimed the card was locked and unreadable. Luckily this program came in clutch and saved my memory card.
Dear etcher mods, I also have this issue, so far I have already tried all the steps in etcher bricker my usb or did it link, the usb has not been used very much, it has been rendered to a state where it shows up as a linux directory on my pc when plugged in that i can access, however it prevents me from booting up on it now, it does not show as a usb, the drive says no media in diskpart and other software, it shows no partitions in diskmanager, i do not have special security rules on my laptop, is it possible ransomware registry is responsible like for the other user? how would i remedy this? also after i installed a dual boot of linux mint with ubuntu and mint froze the usb drive was renamed to 2268 PRAM and became unbootable, before this i could boot with it. I suspect the linux mint install was corrupted and had a hand in this. Please advise on next steps, i have already tried to format it and to use rufus to repair it with no success
Hi all. If you are not succeeded with fixing your drive, it is not the end of the story. Just stop trying to do this on Windows. This OS has a lot of limitations when we talk about managing filesystem and storage.
What helped for me :
I have plugged the drive to PC with Ubuntu and used pre installed “Disks” utility to format the drive to NTFS filesystem. I have checked “Erase” so it will take some time.
If this will not help - try another fixes using terminal. But only on Linux or Mac OS - this is the only way to unbrick.
I’m using Etcher v2.1.4 i recently burned FydeOS and it completed successfully.
When i try to boot through usb it is not showing.
When i tried to format with disk part, the usb is not showing ,in disk management, in linux - lsblk not showing.
In windows i can hear the sound when i connect it.
Etcher mangled two of my drives as well. I used a combination of disk manager and diskpart to find my usb and then remove the extra partition it created. I was still stuck because I was unable to format the disk. I turned to Rufus to do “flash” my ISO and it turns out the Rufus discovered a hidden partition that had been created that windows is unable to see. It was something like 512kb? Anyways, Rufus was able to wipe out the extra partitions that Etcher put on my drive and do the ISO write correctly.
