BalenaEtcher corrupted MBR? Main boot drive no longer shows
Looking ahead to the Windows 10 end of life date I was looking to test Linux Mint on my 2016 Asus laptop. I downloaded the appropriate ISO and then used BalentaEtcher on Windows 10 to create a live USB using the guide on the Linux Mint website
( Create the bootable media — Linux Mint Installation Guide documentation
I didn’t format the USB stick or clear any existing files off as I didn’t see any instruction to do this.
I plugged in the USB stick and then either restarted or shutdown and switched my laptop back on. I wasn’t sure what my key was for getting to the boot menu (Was it F8, enter, esc etc). After a number of attempts I managed to bring up the boot menu where unfortunately the ‘Live USB’ wasn’t an option.
So I went to go back into Windows. So I unplugged the USB stick and restarted my laptop and it went straight to the BIOS… Strange I thought. Tried it a few more times only to realise the boot option for Windows 10 on the C drive SSD had gone!
I tried adding a boot option manually I think by pointing the boot option at the bootmgfw.efi file. But once you hit save and exit on the BIOS it would just loop back to the BIOS again and the boot option I’d just added had disappeared!
So basically I’m stuck with a laptop that can only access the BIOS with no boot options. So maybe a MBR issue? Or maybe an issue with the BIOS itself if it’s not retaining the boot option additions?
Does anyone have any suggestions what might have caused this? And the best way of fixing it ideally. I.e restore access back to the Windows 10 boot option on the C drive.
I had a quick flick through the forums here and didn’t see anyone else recently have this issue so I’m thinking it might be user error on my part..
Thanks.
Small update on this. I can now access Windows 10 if I manually create a boot option by navigating to the bootmgtw.efi file. But strangely it deletes this boot option when you restart. So into the BIOS on every boot.
When I got back into Windows I used Etcher again after reformatting the drive. Error message first time, second time it created the live USB. But same with Windows you have to navigate to the boot file on the USB stick for it to load.
Maybe similar issue. Created bootable image of Linux Mint on USB stick with desktop, then tried to install on new ASUS Zenbook.
Zenbook would not boot from it - failed to find files. Tried different version of Mint - same issue.
When I tried again, BIOS demanded a password (which no-one had set) and other settings changed, so now unable to make any changes to OS - probably including updating Windows, according to ASUS tech, and only option may be to swap motherboard at my expense, because all new MBs have soldered-in ‘security’ chip, which can’t be swapped, and factory reset often doesn’t work - and no-one would believe I hadn’t set a password myself , which is quite understandable
There seems to be some glitch between the Linux Mint .iso and ASUS systems which is corrupting BIOS settings.
