Hi!
I just installed BalenaCam on my Pi3a+ today following every instruction correctly. However, every time I try connecting via my android or win10 PC (chrome), the page loads for a little bit, shows nothing, then shows connection failed. Interestingly, it did work instantly on Edge with using a regular mjpeg stream. What went wrong? How do I fix this? Is there a way (env variables?) to enable mjpeg by default? Please help, here are my logs
26.03.20 19:20:15 (-0700) ======== Running on http://0.0.0.0:80 ========
26.03.20 19:20:15 (-0700) (Press CTRL+C to quit)
26.03.20 19:20:42 (-0700) Task exception was never retrieved
26.03.20 19:20:42 (-0700) future: <Task finished coro=<RTCPeerConnection.__connect() done, defined at /usr/local/lib/python3.5/dist-packages/aiortc/rtcpeerconnection.py:554> exception=ValueError("‘aaf80f4b-a797-43bd-a41a-a383c76567e4.local’ does not appear to be an IPv4 or IPv6 address",)>
26.03.20 19:20:42 (-0700) Traceback (most recent call last):
26.03.20 19:20:42 (-0700) File “/usr/lib/python3.5/asyncio/tasks.py”, line 239, in _step
26.03.20 19:20:42 (-0700) result = coro.send(None)
26.03.20 19:20:42 (-0700) File “/usr/local/lib/python3.5/dist-packages/aiortc/rtcpeerconnection.py”, line 559, in __connect
26.03.20 19:20:42 (-0700) await iceTransport.start(self.__remoteIce[transceiver])
26.03.20 19:20:42 (-0700) File “/usr/local/lib/python3.5/dist-packages/aiortc/rtcicetransport.py”, line 284, in start
26.03.20 19:20:42 (-0700) await self._connection.connect()
26.03.20 19:20:42 (-0700) File “/usr/local/lib/python3.5/dist-packages/aioice/ice.py”, line 356, in connect
26.03.20 19:20:42 (-0700) if (protocol.local_candidate.can_pair_with(remote_candidate) and
26.03.20 19:20:42 (-0700) File “/usr/local/lib/python3.5/dist-packages/aioice/candidate.py”, line 114, in can_pair_with
26.03.20 19:20:42 (-0700) b = ipaddress.ip_address(other.host)
26.03.20 19:20:42 (-0700) File “/usr/lib/python3.5/ipaddress.py”, line 54, in ip_address
26.03.20 19:20:42 (-0700) address)
26.03.20 19:20:42 (-0700) ValueError: ‘aaf80f4b-a797-43bd-a41a-a383c76567e4.local’ does not appear to be an IPv4 or IPv6 address
