Spotify connect on balena sound is dropping out frequently which is pretty frustrating. I haven’t found the exact issue in any other thread. Appears to be an OS ERROR 104 and a subscription validation issue (though I have a valid Spotify Premium sub). Here’s the log info below. Any advice?
spotify [2022-07-30T00:54:27Z INFO librespot_core::session] Connecting to AP "ap-gae2.spotify.com:4070"
spotify [2022-07-30T01:04:28Z WARN librespot] Connection failed: Cannot create session: early eof
spotify [2022-07-30T01:07:16Z INFO librespot_core::session] Connecting to AP "ap-gae2.spotify.com:4070"
spotify [2022-07-30T01:07:17Z INFO librespot_core::session] Authenticated as "hamish.low" !
spotify [2022-07-30T01:07:17Z INFO librespot_playback::mixer::softmixer] Mixing with softvol and volume control: Linear
spotify [2022-07-30T01:07:17Z INFO librespot_playback::convert] Converting with ditherer: tpdf
spotify [2022-07-30T01:07:17Z INFO librespot_playback::audio_backend::pulseaudio] Using PulseAudioSink with format: S16
spotify [2022-07-30T01:07:17Z INFO librespot_core::session] Country: "NZ"
spotify [2022-07-30T01:07:18Z INFO librespot_playback::player] Loading <Paert: Tabula Rasa, I. Ludus - Con moto> with Spotify URI <spotify:track:5dR2YTRxvWDQFqnd7gKUhu>
spotify [2022-07-30T01:07:27Z WARN librespot_playback::player] Player::pause called from invalid state
spotify [2022-07-30T01:07:28Z INFO librespot_playback::player] <Paert: Tabula Rasa, I. Ludus - Con moto> (632106 ms) loaded
spotify [2022-07-30T01:07:28Z WARN librespot_playback::player] This track will at its peak be subject to 4.80 dB of dynamic limiting.
spotify [2022-07-30T01:07:28Z WARN librespot_playback::player] Please lower pregain to avoid.
spotify [2022-07-30T01:07:36Z ERROR librespot_core::session] Connection reset by peer (os error 104)
spotify [2022-07-30T01:07:36Z WARN librespot_audio::fetch::receive] Error from channel for data receiver for range 838972 (+16384).
spotify [2022-07-30T01:07:36Z WARN librespot_audio::fetch::receive] Error from channel for data receiver for range 822588 (+16384).
spotify [2022-07-30T01:07:36Z WARN librespot_audio::fetch::receive] Error from channel for data receiver for range 806204 (+16384).
spotify [2022-07-30T01:07:36Z WARN librespot_audio::fetch::receive] Error from channel for data receiver for range 855356 (+16384).
spotify [2022-07-30T01:07:36Z WARN librespot_audio::fetch::receive] Error from channel for data receiver for range 871740 (+16384).
spotify [2022-07-30T01:07:36Z ERROR librespot_connect::spirc] subscription terminated
spotify [2022-07-30T01:07:36Z WARN librespot] Spirc shut down unexpectedly
