I am trying BalenaCloud for first time. I installed the os in a Raspbeery Pi 3 model B, everything right but after the device is added to my Balena Fleet, the beaconService is showing this error.
Logs
05.10.22 13:53:27 (-0400) beaconService npm ERR! code ELIFECYCLE
05.10.22 13:53:27 (-0400) beaconService npm ERR! errno 1
05.10.22 13:53:27 (-0400) beaconService npm ERR! @ start: node server.js
05.10.22 13:53:27 (-0400) beaconService npm ERR! Exit status 1
05.10.22 13:53:27 (-0400) beaconService npm ERR! Failed at the @ start script.
05.10.22 13:53:27 (-0400) beaconService npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
05.10.22 13:53:27 (-0400) beaconService npm ERR! A complete log of this run can be found in:
05.10.22 13:53:27 (-0400) beaconService npm ERR! /root/.npm/_logs/2022-10-05T17_53_27_626Z-debug.log
05.10.22 13:53:28 (-0400) Service exited ‘beaconService sha256:875648b37d93b676f6b4f63a6dfbda5a0ae9e5cbe07e06b269924e6f13bfee0c’
05.10.22 13:53:28 (-0400) beaconService
05.10.22 13:54:29 (-0400) Restarting service ‘beaconService sha256:875648b37d93b676f6b4f63a6dfbda5a0ae9e5cbe07e06b269924e6f13bfee0c’
05.10.22 13:54:30 (-0400) beaconService
05.10.22 13:54:30 (-0400) beaconService > @ start /app
05.10.22 13:54:30 (-0400) beaconService > node server.js
05.10.22 13:54:31 (-0400) beaconService Started to scan.
05.10.22 13:54:32 (-0400) beaconService Beacon: beacon,device=068d563d4822d3157f1c130571709533,deviceName=dreary-moon,tag=FDA50693-A4E2-4FB1-AFCF-C6EB07647825-5-6 rssi=-30
05.10.22 13:54:34 (-0400) beaconService
05.10.22 13:54:34 (-0400) beaconService ð
05.10.22 13:54:34 (-0400) beaconService 405 Not Allowed
405 Not Allowed
nginx/1.22.0
05.10.22 13:54:34 (-0400) beaconService at Influxdb._fetch (/app/node_modules/influxdb-v2/src/index.js:49:13)
05.10.22 13:54:34 (-0400) beaconService at processTicksAndRejections (internal/process/task_queues.js:97:5)
05.10.22 13:54:34 (-0400) beaconService at async Influxdb.write (/app/node_modules/influxdb-v2/src/index.js:120:12)
05.10.22 13:54:34 (-0400) beaconService at async /app/server.js:111:5
05.10.22 13:54:34 (-0400) beaconService npm ERR! code ELIFECYCLE
05.10.22 13:54:34 (-0400) beaconService npm ERR! errno 1
05.10.22 13:54:34 (-0400) beaconService npm ERR! @ start:
node server.js
05.10.22 13:54:34 (-0400) beaconService npm ERR! Exit status 1
05.10.22 13:54:34 (-0400) beaconService npm ERR! Failed at the @ start script.
05.10.22 13:54:34 (-0400) beaconService npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
05.10.22 13:54:34 (-0400) beaconService npm ERR! A complete log of this run can be found in:
05.10.22 13:54:34 (-0400) beaconService npm ERR! /root/.npm/_logs/2022-10-05T17_54_34_640Z-debug.log
Hope you can help me .
