I’m playing around with openBalena and while running the command balena devices I can see there’s a new column called “Dashboard URL”. The subdomain is not listed in the Getting Started page, is this a new feature or a bug?
Hello, The Dashboard Url column is only applicable when using balenaCloud, since openBalena does not include dashboard functionality. Could you please attach a screenshot? I can then check that the CLI is displaying the devices results as intended for openBalena. Thank you.
Thank you. Ideally we should not be showing that column when the CLI is used with openBalena, so I’ll raise that internally. For now please ignore that column.
