I am using Raspberry pi zero w buld in wifi I have installed jimbobox2 on raspberry pi download
for balena cloud
install balena cli on pc will not work in command prompt ?
it have an auto setup install
I have windows 10 install 64
any help in this area plaese
pi is not showing as connected to balena cloud ?
Hi
Balena should work with the command prompt. I am running balena-cli on a Windows 10 64 bit machine as well, and am able to run balena login, balena devices, and other commands.
- Can you let us know what version of the cli do you have installed? What does your installer file look like?
- Can you confirm that you downloaded the release from here - https://github.com/balena-io/balena-cli/releases/tag/v11.30.17 ? This is the latest release
