short uuid error (device not found)
Hi!
I am an openbalena user (v2.0.0), and balenacli v12.2.2, I have encountered an error while checking the ‘device information’ of a device (rpi4 with balenaOS 2.44.0+rev3):
command
balena device <short-uuid>
stacktrace
BalenaDeviceNotFound: Device not found: <short-uuid>
at /usr/local/lib/balena-cli/node_modules/balena-sdk/build/models/device.js:349:35
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
From previous event:
at /usr/local/lib/balena-cli/node_modules/balena-sdk/build/models/device.js:347:26
at Object.get (/usr/local/lib/balena-cli/node_modules/balena-sdk/build/models/device.js:336:31)
at Object.get (/usr/local/lib/balena-cli/node_modules/balena-sdk/build/util/callbacks.js:19:27)
at DeviceCmd.run (/usr/local/lib/balena-cli/build/actions-oclif/device/index.js:14:38)
at DeviceCmd._run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/command.js:44:31)
at process._tickCallback (internal/process/next_tick.js:68:7)
but when i try the
balena device <long-uuid>
it correctly works.
I have tried others command like balena logs and still doesn’t work with the short uuid, any idea where the problem could be? Or I should stop using the short version?
Matteo
Just another information, which i don’t know if it’s relevant :sweat_smile:
the last events have been registered at:
  • “last_connectivity_event”:“2020-11-23T02:04:14.902Z”,
  • “last_vpn_event”:“2020-11-23T02:04:14.902Z”
how often a device should updates this values?
I don’t see anything related to short-uuid handling in CLI/SDK versions around the time, so I would suspect it’s due to some sort of interaction between the client and the backend. Can you check the API logs? That is, SSH into the API, tail logs with journalctl -fn100 and try the command again.
Thanks for the reply, I got this error
Parsing GET /resin/device(<short-uuid>)?$select=overall_status
Failed to translate url:  {
        "resource": "device",
        "key": {
                "bind": 0
        "options": {
                "$select": {
                        "properties": [
                                        "name": "overall_status",
                                        "property": null
} GET SyntaxError: Could not resolve relationship mapping
    at OData2AbstractSQL.ResolveRelationship (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:514:19)
    at OData2AbstractSQL.ReferencedField (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:562:46)
    at OData2AbstractSQL.AliasSelectField (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:546:38)
    at AddSelectFields._.reject.map.field (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:532:36)
    at arrayMap (/usr/src/app/node_modules/lodash/lodash.js:639:23)
    at Function.map (/usr/src/app/node_modules/lodash/lodash.js:9556:14)
    at interceptor (/usr/src/app/node_modules/lodash/lodash.js:16993:35)
    at thru (/usr/src/app/node_modules/lodash/lodash.js:8797:14)
    at /usr/src/app/node_modules/lodash/lodash.js:4374:28
    at arrayReduce (/usr/src/app/node_modules/lodash/lodash.js:683:21)
    at baseWrapperValue (/usr/src/app/node_modules/lodash/lodash.js:4373:14)
    at LazyWrapper.lazyValue [as value] (/usr/src/app/node_modules/lodash/lodash.js:1859:16)
    at baseWrapperValue (/usr/src/app/node_modules/lodash/lodash.js:4371:25)
    at LodashWrapper.wrapperValue (/usr/src/app/node_modules/lodash/lodash.js:9052:14)
    at OData2AbstractSQL.AddSelectFields (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:533:18)
    at OData2AbstractSQL.PathSegment (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:351:18)
    at OData2AbstractSQL.match (/usr/src/app/node_modules/@resin/odata-to-abstract-sql/out/odata-to-abstract-sql.js:177:32)
    at memoizeWeak (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/uri-parser.js:55:51)
    at /usr/src/app/node_modules/es5-ext/function/#/partial.js:14:16
    at /usr/src/app/node_modules/memoizee/lib/configure-map.js:61:24
    at /usr/src/app/node_modules/memoizee/lib/weak.js:87:21
    at memoizedOdata2AbstractSQL (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/uri-parser.js:78:56)
    at exports.translateUri (/usr/src/app/node_modules/@resin/pinejs/out/sbvr-api/uri-parser.js:184:34)
    at tryCatcher (/usr/src/app/node_modules/bluebird/js/release/util.js:16:23)
    at Promise._settlePromiseFromHandler (/usr/src/app/node_modules/bluebird/js/release/promise.js:512:31)
    at Promise._settlePromise (/usr/src/app/node_modules/bluebird/js/release/promise.js:569:18)
    at Promise._settlePromise0 (/usr/src/app/node_modules/bluebird/js/release/promise.js:614:10)
    at Promise._settlePromises (/usr/src/app/node_modules/bluebird/js/release/promise.js:694:18)
    at Promise._fulfill (/usr/src/app/node_modules/bluebird/js/release/promise.js:638:18)
    at Promise._resolveCallback (/usr/src/app/node_modules/bluebird/js/release/promise.js:432:57)
    at Promise._settlePromiseFromHandler (/usr/src/app/node_modules/bluebird/js/release/promise.js:524:17)
    at MappingPromiseArray.PromiseArray._resolve (/usr/src/app/node_modules/bluebird/js/release/promise_array.js:126:19)
    at MappingPromiseArray._promiseFulfilled (/usr/src/app/node_modules/bluebird/js/release/map.js:101:18)
    at Promise._settlePromise (/usr/src/app/node_modules/bluebird/js/release/promise.js:574:26)
    at Holder$2._callFunction (<anonymous>:19:29)
    at _drainQueueStep (/usr/src/app/node_modules/bluebird/js/release/async.js:142:12)
    at _drainQueue (/usr/src/app/node_modules/bluebird/js/release/async.js:131:9)
    at Async._drainQueues (/usr/src/app/node_modules/bluebird/js/release/async.js:147:5)
    at Immediate.Async.drainQueues [as _onImmediate] (/usr/src/app/node_modules/bluebird/js/release/async.js:17:14)
    at process.topLevelDomainCallback (domain.js:120:23)
Yeah, I see now. The last supported CLI version for open-balena v2.X is in fact v12.2.1. I now see the note we had about this was quite confusing, in that it said “<12.2.2” which means “less than but not equal”. CLI v12.2.2 introduced the breaking change. Everything should work fine if you downgrade to v12.2.1, or upgrade openBalena to v3.X. Apologies for the confusion.
I have done the downgrade to balenaCli 12.2.1
now both the commands with short/long uuid give an error, but only with the ‘balena device’ command (balena logs now works)
[debug] original argv0="/usr/local/lib/balena-cli/bin/node" argv=[/usr/local/lib/balena-cli/bin/node,/usr/local/lib/balena-cli/bin/run,device, <long-uuid>] length=4
[debug] new argv=[/usr/local/lib/balena-cli/bin/node,/usr/local/lib/balena-cli/bin/run,device, <long-uuid>] length=4
BalenaRequestError: Request error: Internal Server Error
    at /usr/local/lib/balena-cli/node_modules/balena-request/build/request.js:189:17
    at /usr/local/lib/balena-cli/node_modules/balena-request/build/request.js:181:62
    at Object.exports.send (/usr/local/lib/balena-cli/node_modules/balena-request/build/request.js:180:8)
    at /usr/local/lib/balena-cli/node_modules/balena-sdk/node_modules/balena-pine/es5/index.js:37:22
    at BalenaPine._request (/usr/local/lib/balena-cli/node_modules/balena-sdk/node_modules/balena-pine/es5/index.js:29:34)
    at BalenaPine.PinejsClientCoreFactory.PinejsClientCore.request (/usr/local/lib/balena-cli/node_modules/pinejs-client-core/es5/index.js:982:29)
    at BalenaPine.PinejsClientCoreTemplate.get (/usr/local/lib/balena-cli/node_modules/pinejs-client-core/es5/index.js:749:21)
    at /usr/local/lib/balena-cli/node_modules/balena-sdk/build/models/device.js:355:26
    at Object.getStatus (/usr/local/lib/balena-cli/node_modules/balena-sdk/build/models/device.js:2167:18)
    at Object.getStatus (/usr/local/lib/balena-cli/node_modules/balena-sdk/build/util/callbacks.js:19:27)
    at DeviceCmd.run (/usr/local/lib/balena-cli/build/actions-oclif/device/index.js:14:61)
server:
Parsing GET /resin/device?$filter=startswith(uuid,%<longuuid>%27)&$select=overall_status
        "options": {
                "$filter": [
                        "call",
                                "args": [
                                                "name": "uuid",
                                                "property": null
                                                "bind": 0
                                "method": "startswith"
                "$select": {
                        "properties": [
                                        "property": null
Hi there,
Can you clarify how you downgraded the CLI and provide the result of balena version please? Version v12.2.1 shouldn’t be referencing the faulty overall_status field at all, so perhaps something went wrong in your downgrade.
I have downloaded and installed this tag version https://github.com/balena-io/balena-cli/releases/download/v12.2.1/balena-cli-v12.2.1-macOS-x64-installer.pkg
balena --version
12.2.1
Hi Matteo. It’s possible that the downgrade left behind some files from the newest version. Could you try removing the /usr/local/lib/balena-cli/ folder and installing v12.2.1 of the CLI again?
