balena cli version 12.22 (I believe the latest) will not deploy my app. It works fine with 11.35.10. It gets to the point
[Info] Everything is up to date (use --build to force a rebuild)
then exits with code 0. Normally it will be followed with
[Info] Creating release…
[Info] Pushing images to registry…
[Info] Saving release…
[Success] Deploy succeeded!
@cpsamtec, thank you for reporting this issue. Indeed it was a bug introduced in CLI v12.14.18 (ironically during a refactoring that was supposed to improve codebase reliability). It has been fixed in CLI v12.22.2. Let us know if you are able to test it and/or if you are still facing any issues. I will look at improving test coverage for the deploy command, to prevent regressions. Thanks again.
