I am trying to deploy a Docker container with balena deploy app image which used to work but now I get this error:
Version: 11.30.12
$ ~/opt/balena-cli/balena deploy first-nuc 123456789012.dkr.ecr.eu-west-1.amazonaws.com/automation/xxx/yyyv1.0.18-linux-amd64
Error: no "Dockerfile[.*]", "docker-compose.yml" or "package.json" file
found in source folder "."
ExpectedError: Error: no "Dockerfile[.*]", "docker-compose.yml" or "package.json" file
at validateProjectDirectory (/usr/local/Cellar/balena-cli/11.30.6/libexec/lib/node_modules/balena-cli/build/utils/compose_ts.js:256:19)
From previous event:
at processImmediate (internal/timers.js:456:21)
at Command.action (/usr/local/Cellar/balena-cli/11.30.6/libexec/lib/node_modules/balena-cli/build/actions/deploy.js:167:8)
at /usr/local/Cellar/balena-cli/11.30.6/libexec/lib/node_modules/balena-cli/node_modules/capitano/build/command.js:98:37
at runNextTicks (internal/process/task_queues.js:62:5)
at processImmediate (internal/timers.js:429:9)
at process.topLevelDomainCallback (domain.js:137:15)
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
