at start up white screen
From what I understand you are having trouble running balenaEtcher on Windows 11. I tried reproducing on my Windows 11 machine using the latest version found on balenaEtcher - Flash OS images to SD cards & USB drives but had no issues.
Are you using the latest version (v1.19.25 as of now) downloaded from the link above? Also possibly a screenshot could prove useful.
yes iam using latest version v1.19. 25 from tha balenaetcher hpme page and frim other places to i get the results
Hi @wethepeople1 , I’m unaware of any recent changes/fixes that would be directly related to your problem but there is a new version (v2.1.0) available if you can give it a try: https://etcher.balena.io/
Also, does the problem persist even when you run the application as an administrator?
