Application not updating to latest release
Hi @cfhull
Another reason why an application might not update to the latest release is an application lock - see our documentation. Can you confirm that there is no application lock present?
Also, it might be worth checking whether a hyphen in an environment variable could be the culprit, as in this forums discussion. Which versions of balenaOS and supervisor are you running?
Kind regards
Alida
