I am new to RP and Balena. Just put together my RP4 + Allo Boss Dac v1.2 + ISOLATOR V1.2. I powered RP4 from the Isolator and Dac from itself. Airplay works fine but nothing comes out of the RCAs! Any suggestions? I’ve added the BALENA_HOST_CONFIG_dtoverlay for allo-boss-dac-pcm512x-audio. I’ve forced the output to check for DAC. I don’t know what else I need to do! I just checked and nothing comes out of the RP audio jack either! I use the latest version balenaOS 2.73.1+rev1
Define DT parameters “i2c_arm=on”,“spi=on”,“audio=on”
Define DT overlays “vc4-fkms-v3d”
AUDIO_OUTPUT DAC
SOUND_DEVICE DAC
Nothing comes with: dmesg | grep hifi
Log shows the Dac is not found:
24.03.21 22:42:28 (+0000) audio WARNING: No DAC found. Falling back to PulseAudio defaults.
24.03.21 22:42:28 (+0000) audio Setting audio routing rules…
24.03.21 22:42:28 (+0000) audio Routing ‘balena-sound.input’ to ‘snapcast’.
24.03.21 22:42:28 (+0000) audio Routing ‘balena-sound.output’ to ‘0’.
24.03.21 22:42:28 (+0000) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
24.03.21 22:42:29 (+0000) multiroom-client 2021-03-24 22-42-29.148 [Error] (Controller) Failed to send hello request, error: Connection timed out
24.03.21 22:42:29 (+0000) multiroom-client 2021-03-24 22-42-29.148 [Error] (Controller) Time sync request failed: Connection timed out
24.03.21 22:42:29 (+0000) audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
24.03.21 22:42:29 (+0000) audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
root@7713a6f:~# dmesg | grep snd
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:EC:A5:6C vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 dwc_otg.lpm_enable=0 console=tty1 console=ttyS0,115200 rootwait cgroup_enable=memory root=UUID=ba1eadef-192f-49d4-b5a9-0fb092554bef rootwait
[ 8.869584] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.978969] snd-allo-boss-dac soc:sound: ASoC: failed to init link Boss DAC: -517
[ 9.018730] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 9.149658] snd-allo-boss-dac soc:sound: ASoC: failed to init link Boss DAC: -517
[ 9.158356] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 9.177913] snd-allo-boss-dac soc:sound: ASoC: failed to init link Boss DAC: -517
[ 9.187295] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 9.195351] snd-allo-boss-dac soc:sound: ASoC: failed to init link Boss DAC: -517
[ 9.203818] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
[ 9.239670] snd-allo-boss-dac soc:sound: ASoC: failed to init link Boss DAC: -517
[ 9.247499] snd-allo-boss-dac soc:sound: snd_soc_register_card() failed: -517
