Trying to get BalenaSound working with Raspberry Pi 3B. I have found that after a reboot, I have to refresh Airplay service in the cloud app before the device shows up as an option for Airplay. Otherwise it does not show up at all or shows up intermittently and cuts out after a few seconds just like the bluetooth does on the 3B. After refreshing, Airplay functions properly, but this has to be done every time the Pi reboots or when a variable is altered.
As an aside, I noticed that the official guide lists the Raspberry Pi 3B as recommended alongside the 4B in the “Hardware Required” section. However, the troubleshooting guide shows that the 3B has issues with bluetooth connectivity such that the recommended workaround is to use a USB dongle. I would suggest this Pi model not be recommended alongside the Pi 4 in the getting started guide given this issue.
@mpous thanks for your help. I used the Raspberry Pi 3 option to flash the SD card, and the architecture is listed as armv7hf, which means 32-bit OS, correct?
Hey @mkp132 can you share your device logs? Try to capture them from reboot onwards. If you have the balenaCloud web dashboard open and reboot from there it should be fine. Then there is a download button to grab them.
I had reported this problem (along with others) as well, a few weeks ago, maybe around the same time as these posts. I was looking at it as a “nuisance,” but would be nice to have it fixed.
When we do have a new version of balenaSound we will update this thread accordingly. At that time you can either Deploy With Balena via the GitHub page, or clone the latest release and use the balena CLI to push a newer version of the app.
