adding a service env var reboots container ! is that intended behaviour ?
start service
add a service env var value
container gets rebooted !
Hi osde8info,
Yes, services restart when device and fleet-wide variables are added, removed or changed. Everything should work properly and the variables should be set (and available) once the services restart. Can you confirm that?
John
absobloominglutely see rosetta@home : how to check you secret key is working for the proof
however i was expecting to have to manually reboot container AFTER changing SERVICE var
Hi osde8info,
Yes, changes in service, device or fleet variables will trigger service restarts (though not explicitly referenced in the serv-vars docs.
John
maybe a doc update is due ?
