Hey folks,
Any chance it would be possible to add local IP (and .local) support to balena tunnel, similar to balena ssh? Obviously it’s not technically necessary since you can access the device directly on the LAN and tunnel manually via ssh, but just like balena ssh, it’s convenient to be able to use the same syntax and URL configurations for local devices as for remote devices but bypassing the Balena proxy for speed. Just a thought.
Adam
