I think I did. I chose to manually upload it instead of using github. This is what the form looked like before I submitted, and I can see it listed in my account preferences SSH Keys tab. But should I need an SSH key for local development?
This page mentions that
Note: If an IP address or a .local hostname is used (instead of a fleet name or device UUID), balena ssh establishes a direct connection to the device on port 22222 that does not rely on cloudlink.
If I run balena ssh [UUID of device] then it works. But I want to connect locally to hopefully reduce lag.
This is the output with the verbose option
balena ssh 4bb5b53.local --verbose
OpenSSH_8.9p1 Ubuntu-3, OpenSSL 3.0.2 15 Mar 2022
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug2: resolving "4bb5b53.local" port 22222
debug3: resolve_host: lookup 4bb5b53.local:22222
debug3: ssh_connect_direct: entering
debug1: Connecting to 4bb5b53.local [10.4.4.194] port 22222.
debug3: set_sock_tos: set socket 3 IP_TOS 0x10
debug1: Connection established.
debug1: identity file /home/pateco/.ssh/id_rsa type 0
debug1: identity file /home/pateco/.ssh/id_rsa-cert type -1
debug1: identity file /home/pateco/.ssh/id_ecdsa type -1
debug1: identity file /home/pateco/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/pateco/.ssh/id_ecdsa_sk type -1
debug1: identity file /home/pateco/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /home/pateco/.ssh/id_ed25519 type 3
debug1: identity file /home/pateco/.ssh/id_ed25519-cert type -1
debug1: identity file /home/pateco/.ssh/id_ed25519_sk type -1
debug1: identity file /home/pateco/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /home/pateco/.ssh/id_xmss type -1
debug1: identity file /home/pateco/.ssh/id_xmss-cert type -1
debug1: identity file /home/pateco/.ssh/id_dsa type -1
debug1: identity file /home/pateco/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.9p1 Ubuntu-3
debug1: Remote protocol version 2.0, remote software version dropbear_2017.75
debug1: compat_banner: no match: dropbear_2017.75
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 4bb5b53.local:22222 as 'pateco'
debug3: put_host_port: [4bb5b53.local]:22222
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug3: order_hostkeyalgs: no algorithms matched; accept original
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,sntrup761x25519-sha512@openssh.com,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c
debug2: host key algorithms: ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-ed25519,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,rsa-sha2-512,rsa-sha2-256
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256@libssh.org,ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group14-sha1,kexguess2@matt.ucc.asn.au
debug2: host key algorithms: ssh-rsa
debug2: ciphers ctos: aes128-ctr,aes256-ctr
debug2: ciphers stoc: aes128-ctr,aes256-ctr
debug2: MACs ctos: hmac-sha1,hmac-sha2-256,hmac-sha2-512,hmac-md5
debug2: MACs stoc: hmac-sha1,hmac-sha2-256,hmac-sha2-512,hmac-md5
debug2: compression ctos: zlib@openssh.com,none
debug2: compression stoc: zlib@openssh.com,none
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: (no match)
Unable to negotiate with 10.4.4.194 port 22222: no matching host key type found. Their offer: ssh-rsa
SSH: Process exited with non-zero status code "255"
Are the SSH keys correctly configured in balenaCloud? See:
https://www.balena.io/docs/learn/manage/ssh-access/#add-an-ssh-key-to-balenacloud
Are you accidentally using `sudo`?
