Installing Etcher 1.4.9 for a Fedora 28 KDE Desktop. I’m seeing a massive 125 unmet dependencies!
Does that seem plausible?
Installing | dependencies: |
annobin | |
cpp | |
dwz | |
fpc-srpm-macros | |
gcc | |
gcc-c++ | |
ghc-srpm-macros | |
gnat-srpm-macros | |
go-srpm-macros | |
isl | |
libmpc | |
libpng12 | |
nim-srpm-macros | |
ocaml-srpm-macros | |
openblas-srpm-macros | |
perl-Algorithm-Diff | |
perl-Archive-Tar | |
perl-Archive-Zip | |
perl-B-Lint | |
perl-CGI | |
perl-CPAN | |
perl-CPAN-Meta | |
perl-CPAN-Meta-Requirements | |
perl-CPAN-Meta-YAML | |
perl-Class-ISA | |
perl-Compress-Bzip2 | |
perl-Compress-Raw-Bzip2 | |
perl-Compress-Raw-Zlib | |
perl-Data-Dump | |
perl-Data-OptList | |
perl-Data-Section | |
perl-Devel-PPPort | |
perl-Devel-Size | |
perl-Digest-HMAC | |
perl-Digest-SHA | |
perl-Encode-Locale | |
perl-Env | |
perl-ExtUtils-CBuilder | |
perl-ExtUtils-Command | |
perl-ExtUtils-Install | |
perl-ExtUtils-MM-Utils | |
perl-ExtUtils-MakeMaker | |
perl-ExtUtils-Manifest | |
perl-ExtUtils-ParseXS | |
perl-File-CheckTree | |
perl-File-HomeDir | |
perl-File-Listing | |
perl-File-Which | |
perl-HTML-Parser | |
perl-HTML-Tagset | |
perl-HTTP-Cookies | |
perl-HTTP-Date | |
perl-HTTP-Message | |
perl-HTTP-Negotiate | |
perl-IO-Compress | |
perl-IO-HTML | |
perl-IO-Zlib | |
perl-IPC-Cmd | |
perl-IPC-System-Simple | |
perl-JSON-PP | |
perl-LWP-MediaTypes | |
perl-Locale-Codes | |
perl-Locale-Maketext | |
perl-Locale-Maketext-Simple | |
perl-MRO-Compat | |
perl-Module-Build | |
perl-Module-CoreList | |
perl-Module-Load | |
perl-Module-Load-Conditional | |
perl-Module-Metadata | |
perl-Module-Pluggable | |
perl-NTLM | |
perl-Net-HTTP | |
perl-Net-Ping | |
perl-Package-Generator | |
perl-Params-Check | |
perl-Params-Util | |
perl-Perl-OSType | |
perl-Pod-Checker | |
perl-Pod-Html | |
perl-Pod-LaTeX | |
perl-Pod-Parser | |
perl-Pod-Plainer | |
perl-Software-License | |
perl-Sub-Exporter | |
perl-Sub-Install | |
perl-Sys-Syslog | |
perl-Test-Harness | |
perl-Test-Simple | |
perl-Text-Diff | |
perl-Text-Glob | |
perl-Text-Soundex | |
perl-Text-Template | |
perl-Text-Unidecode | |
perl-Time-HiRes | |
perl-TimeDate | |
perl-Try-Tiny | |
perl-WWW-RobotRules | |
perl-XML-LibXML | |
perl-XML-NamespaceSupport | |
perl-XML-SAX | |
perl-XML-SAX-Base | |
perl-autodie | |
perl-devel | |
perl-inc-latest | |
perl-libwww-perl | |
perl-local-lib | |
perl-srpm-macros | |
perl-version | |
python-srpm-macros | |
python3-pyparsing | |
qt3 | |
qt5-srpm-macros | |
redhat-lsb | |
redhat-lsb-cxx | |
redhat-lsb-desktop | |
redhat-lsb-languages | |
redhat-lsb-printing | |
redhat-lsb-submod-multimedia | |
redhat-rpm-config | |
rust-srpm-macros | |
systemtap-sdt-devel | |
Installing | weak |
perl-Module-Runtime | |
perl-TermReadKey |
