Writer process ended unexpectedly
I an trying to use Etcher version 1.5.63 under Windows 8.1 (64-bit) to write the image D:\XPS_8700 Extended Files\Users\RowanB\Downloads\2019-09-26-raspbian-buster.img to an unbranded 64GB Micro SD card in drive G: (a card reader slot in my desktop PC). When I do so I get this.
What am I doing wrong? How do I get this image written to the card?
Is there a log somewhere that tells me what is going wrong? If so, where?
Thanks - Rowan
It seems like you hit this issue (https://github.com/balena-io/etcher/issues/2950). Could you open the DevTools Console (ctrl + shift + i) and provide us with the logs so that we can investigate this in more detail?
Thank you.
Thank you for you r reply. Here is the log:
@rowan.bradley no logs where attached do you mind re sending them? Paste them here maybe?
========================Are these the logs you need? These were
included in my last message. ================================== If I
need to send something else, please explain how I find it.
C:\Users\RowanB\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58
Download the React DevTools for a better development experience: You might need to use a local HTTP server (instead of ): C:\Users\RowanB\AppData\Local\Programs\balena-etcher\resources\app.asar\node_modules\raven-js\dist\raven.js:58
___| | | |
__ | |_ | | ___ _ __
__|| _/ | ’ \ / _ \ '|
_
/ _
_|| ||_|_|
Interested in joining the Etcher team?
Drop us a line at Version = 1.5.63, Type = nsis
Mon Nov 25 2019 12:29:06 GMT+0000 (GMT Standard Time) Application
start
({“packageType”:“nsis”,“version”:“1.5.63”,“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“sample”:0.1})
Mon Nov 25 2019 12:29:18 GMT+0000 (GMT Standard Time) Open image
selector
({“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:19 GMT+0000 (GMT Standard Time) SafeWebview
loaded
({“event”:{“fromCache”:false,“headers”:{“Accept”:“text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,/;q=0.8”,“Upgrade-Insecure-Requests”:“1”,“User-Agent”:“Mozilla/5.0
(Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko)
balena-etcher/1.5.63 Chrome/66.0.3359.181 Electron/3.1.9
Safari/537.36”},“id”:14,“method”:“GET”,“referrer”:“”,“resourceType”:“mainFrame”,“responseHeaders”:{“Accept-Ranges”:[“bytes”],“Cache-Control”:[“public,
max-age=0”],“Connection”:[“keep-alive”],“Content-Encoding”:[“gzip”],“Content-Type”:[“text/html;
charset=UTF-8”],“Date”:[“Mon, 25 Nov 2019 12:29:25
GMT”],“Etag”:[“W/"3c810-16e8d73c970"”],“Last-Modified”:[“Thu, 21
Nov 2019 10:13:26
GMT”],“Server”:[“Cowboy”],“Transfer-Encoding”:[“chunked”],“Vary”:[“Accept-Encoding”],“Via”:[“1.1
vegur, 1.1 vegur”]},“statusCode”:200,“statusLine”:“HTTP/1.1 200
OK”,“timestamp”:1574684959386.904,“url”:},“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:33 GMT+0000 (GMT Standard Time) Select image
({“image”:{“size”:3829399552,“name”:“2019-09-26-raspbian-buster.img”,“hasMBR”:true,“partitions”:[{“offset”:4194304,“size”:268435456,“type”:12,“index”:1},{“offset”:272629760,“size”:3556769792,“type”:131,“index”:2}],“path”:“D:\XPS_8700
Extended
Files\Users\RowanB\Downloads\2019-09-26-raspbian-buster.img”,“extension”:“img”,“logo”:false,“blockMap”:false},“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:36 GMT+0000 (GMT Standard Time) Open modal
({“name”:“drive-selector”,“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:39 GMT+0000 (GMT Standard Time) Toggle drive
({“drive”:{“size”:67109912576,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive4”,“error”:null,“isReadOnly”:false,“displayName”:“G:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive4”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“G:\”}],“description”:“Generic-
SD/MMC USB
Device”,“isUAS”:false},“previouslySelected”:false,“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:41 GMT+0000 (GMT Standard Time) Modal accepted
Mon Nov 25 2019 12:29:43 GMT+0000 (GMT Standard Time) Open modal
({“name”:“warning”,“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:47 GMT+0000 (GMT Standard Time) Modal accepted
({“name”:“warning”,“value”:true,“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:47 GMT+0000 (GMT Standard Time) Flashing 0
devices, 0% at null MB/s (total null MB/s) eta in undefineds with 0
failed devices
({“image”:“D:\XPS_8700 Extended
Files\Users\RowanB\Downloads\2019-09-26-raspbian-buster.img”,“drives”:[{“size”:67109912576,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive4”,“error”:null,“isReadOnly”:false,“displayName”:“G:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive4”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“G:\”}],“description”:“Generic-
SD/MMC USB
Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“0b971da0-5a21-4f9e-b136-b0dd099acb13”,“status”:“started”,“flashInstanceUuid”:“0b971da0-5a21-4f9e-b136-b0dd099acb13”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“trim”:false,“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Elevating command:
C:\Users\RowanB\AppData\Local\Programs\balena-etcher\balenaEtcher.exe
Mon Nov 25 2019 12:29:50 GMT+0000 (GMT Standard Time) SafeWebview
loaded
Safari/537.36”},“id”:29,“method”:“GET”,“referrer”:“”,“resourceType”:“mainFrame”,“responseHeaders”:{“access-control-allow-origin”:[“*”],“age”:[“237”],“cache-control”:[“max-age=600”],“cf-cache-status”:[“DYNAMIC”],“cf-ray”:[“53b3a186ed1dbbf4-LHR”],“content-encoding”:[“br”],“content-type”:[“text/html;
charset=utf-8”],“date”:[“Mon, 25 Nov 2019 12:29:55
GMT”],“expect-ct”:[“max-age=604800, report-uri="],“expires”:[“Fri,
22 Nov 2019 08:19:40 GMT”],“last-modified”:[“Wed, 06 Nov 2019
11:17:56
GMT”],“server”:[“cloudflare”],“status”:[“200”],“vary”:[“Accept-Encoding”],“via”:[“1.1
varnish”],“x-cache”:[“HIT”],“x-cache-hits”:[“1”],“x-fastly-request-id”:[“496d876417011e01d7a712c5a0aab20616d791cb”],“x-github-request-id”:[“F366:363B:57057:7A7E7:5DD797C3”],“x-proxy-cache”:[“MISS”],“x-served-by”:[“cache-lcy19262-LCY”],“x-timer”:[“S1574684996.677472,VS0,VE0”]},“statusCode”:200,“statusLine”:“HTTP/1.1
200”,“timestamp”:1574684989478.502,“url”:},“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“sample”:0.1})
Mon Nov 25 2019 12:29:50 GMT+0000 (GMT Standard Time) Flashing 0
failed devices
Successfully connected to IPC server: etcher-server-31912, socket
root C:\Users\RowanB\AppData\Local\Temp
Image: D:\XPS_8700 Extended
Devices: \.\PhysicalDrive4
Umount on success: true
Validate on success: true
Trim: false
Mon Nov 25 2019 12:30:32 GMT+0000 (GMT Standard Time) Flash error
({“error”:{“name”:“Error”,“message”:“EPERM: operation not permitted,
write”,“stack”:“Error: EPERM: operation not permitted,
write”,“code”:“EPERM”,“syscall”:“write”,“errno”:-4048},“applicationSessionUuid”:“b711deb2-04cb-41b0-8cc6-7cfb1d6133ec”,“flashingWorkflowUuid”:“2c5dba75-68d3-491a-a982-3821ef89efc0”,“flashInstanceUuid”:“0b971da0-5a21-4f9e-b136-b0dd099acb13”,“image”:“D:\XPS_8700
Extended
Files\Users\RowanB\Downloads\2019-09-26-raspbian-buster.img”,“drives”:[{“size”:67109912576,“isVirtual”:false,“enumerator”:“USBSTOR”,“logicalBlockSize”:512,“raw”:”\\.\PhysicalDrive4",“error”:null,“isReadOnly”:false,“displayName”:“G:\”,“blockSize”:512,“isSCSI”:false,“isRemovable”:true,“device”:“\\.\PhysicalDrive4”,“busVersion”:“2.0”,“isSystem”:false,“busType”:“USB”,“isCard”:false,“isUSB”:true,“devicePath”:null,“mountpoints”:[{“path”:“G:\”}],“description”:“Generic-
SD/MMC USB
Device”,“isUAS”:false}],“driveCount”:1,“uuid”:“0b971da0-5a21-4f9e-b136-b0dd099acb13”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“trim”:false,“sample”:0.1})
Finish: 0
Flash results Object
Terminating IPC server
Mon Nov 25 2019 12:30:35 GMT+0000 (GMT Standard Time) Open modal
Hi, thank you for the logs.
Could you check that you haven’t got the Controlled folder access Windows setting enabled?
You can do so by pressing the Win key, searching for Controlled folder access then either allow Etcher in it or disable the setting completely.
If that still doesn’t work/the setting is already disabled (or Etcher already has an exception in it), you can also try running as administrator, but I’d advise to do so only afterwards.
Thanks for your reply.
I’m sorry, I don’t know how to do this.
  If I press the Win key, I see the Start menu. If I enter
“Controlled folder access” in the Search box, and press Return, it
eventually finds lots of things, but none of them look relevant.
  If I search the internet for Controlled Folder Access, I find the
following instructions:
Use controlled folder access
            Controlled folder access in
Windows Security reviews the apps that can make changes
to files in protected folders. Occasionally, an app that
is safe to use will be identified as harmful. This
happens because Microsoft wants to keep you safe and
will sometimes err on the side of caution; however, this
might interfere with how you normally use your PC. You
can add an app to the list of safe or allowed apps to
prevent them from being blocked.
  • Select Start > Settings > Update & Security > Windows Security > Virus & threat protection.
  • Under ** Virus & threat protection
    settings** ,
    select ** Manage
    settings**.
  • Under Controlled folder access, select Manage Controlled folder access.
  •                   Switch
    the ** Controlled
    folder access** setting
    to On or Off.
  If I select the Start menu, there is no item Settings. There is
PC Settings, but this does not contain any item Update and
Security.
How do I get to Controlled Folder Access?
Thanks - Rowan
There’s an alternative explanation of how to do this here: https://support.microsoft.com/en-us/help/4046851/windows-10-allow-blocked-app-windows-security
Please let us know if that works for you!
Sorry, no, it doesn’t. The problem is that in the Start menu,
there is no item Settings. I am using Windows 8.1. Maybe the
problem is that I’m using the Traditional Start Menu add-in. I’m
not sure how to disable this.
Any other suggestions?
Thank you - Rowan
Ah, I believe that Controlled Folder Access feature is not present in Windows 8.1, so we can ignore that. Could you try logging in / running etcher as administrator, if you have not already?
Sorry, I don’t know how to do that either. Currently there is only one user registered on my PC, RowanB, who is a “local systems administrator”. Do I just need to run the Etcher as this user? If so, then that is what I have already done (which causes the error). Or do I have to be a higher level administrator than “local systems administrator”? If so, how do I create such an account? Or do I have to run it as the username “administrator”? If so, how do I create this account?
Sorry to be so dumb…
Thank you - Rowan
@rowan.bradley here’s some information on running programs as administrator on Windows 8.1: https://ccm.net/faq/35280-windows-8-1-how-to-run-a-program-as-administrator
Chris,
  Thanks for your further help. If I run Etcher using the method
described in this link, then it seems to run better. But at the
end of the process, it says that there is a checksum error:
  If I try to open the memory card slot containing the supposedly
flashed card, it says “Please insert a disk into the Removable
Disk (G:)”, just like it does for an empty slot. I don’t know
whereto Windows should be able to read the flashed card,
or not.
  I have attached the log (zipped, since your email system rejected
it as too big without zipping).
  Please can you suggest what may be wrong, or how I can
investigate this further?
Thank you - Rowan
(Attachment EtcherLog191127.zip is missing)
Chris,
or not.
it as too big without zipping). You will need to rename it back to
.zip (I had to change it because your e-mail system will not
accept ZIP files).
Thank you - Rowan
EtcherLog191127.log (10.7 KB)
Hey Rowan,
We’re glad the method described above made thing better.
What you see is a legit warning, and its Etcher telling you that what was written to the drive doesn’t exactly match the image you were flashing, as a protection mechanism. This is usually the case with faulty SD Cards, SD Card readers, electromagnetism, etc. Can you try again, and potentially with a different i.e. adapter and see if that makes a difference?
I have tried using a different adapter. It gave the same error:
  I have ordered some more micro SD cards and will try with one of
those when they arrive.
  Should I be able to read the files written to the card with my
Windows PC? I can’t. Does this suggest something more dramatic is
wrong with the process, e.g. the card is formatted in the wrong
way? Does the card need to be formatted before being flashed, or
does the flashing process effectively format it? The first time I
tried flashing it, I formatted it first, and disabled the “fast
format” feature, which meant that it took nearly 24 hours to
format the card.
Thanks for your help - Rowan
Hi there,
If you have a spare SD card available, I would recommend testing that as well since we often see corruption of the physical media.
Please let us know how that test goes for you when you are able to complete it!
