I’m trying to use Wifi Connect for the first time. I’ve got a Raspberry Pi 3 Compute Module with a Redpine RS9113 Wifi Module. I don’t know of it’s one of the supported boards and trying to get things working.
I’ve got Wifi-connect installed and running on a balenaOS multicontainer app
Checking system settings (from Balena Host OS)
# systemctl status NetworkManager
Warning: The unit file, source configuration file or drop-ins of NetworkManager.service changed on disk. Run 'systemctl daemon-reload' to reload units.
● NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/NetworkManager.service.d
└─NetworkManager.conf
Active: active (running) since Tue 2020-02-25 21:39:54 UTC; 1 months 23 days ago
Docs: man:NetworkManager(8)
Main PID: 745 (NetworkManager)
Tasks: 3 (limit: 2215)
Memory: 9.7M
CGroup: /system.slice/NetworkManager.service
└─745 /usr/sbin/NetworkManager --no-daemon
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.0487] device (wifi0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.0503] device (wifi0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.0535] manager: NetworkManager state is now CONNECTED_LOCAL
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.0649] manager: NetworkManager state is now CONNECTED_SITE
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.0704] policy: set 'resin-wifi-01' (wifi0) as default for IPv4 routing and DNS
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.0779] dns-mgr: Writing DNS information to /sbin/resolvconf
Feb 25 21:40:11 a705845 NetworkManager[745]: <info> [1582666811.1777] device (wifi0): Activation: successful, device activated.
Feb 25 21:40:13 a705845 NetworkManager[745]: <info> [1582666813.8764] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 25 21:40:17 a705845 NetworkManager[745]: <info> [1582666817.3783] manager: (resin-vpn): new Tun device (/org/freedesktop/NetworkManager/Devices/8)
Apr 19 22:44:58 a705845 NetworkManager[745]: <info> [1587336298.4805] bluez: use BlueZ version 5
# nmcli d
DEVICE TYPE STATE CONNECTION
wifi0 wifi connected resin-wifi-01
supervisor0 bridge connected supervisor0
rpine0 ethernet unavailable --
balena0 bridge unmanaged --
br-d0b1d9af1186 bridge unmanaged --
resin-dns bridge unmanaged --
lo loopback unmanaged --
resin-vpn tun unmanaged --
Tried with
./wifi-connect -i wifi0 -s "NickConnect" -p "testpass"(as part ofstart.sh), whileNickHotspotnot up and RPi not connected. Didn’t see the network pop up. -
Tried with
./wifi-connect -i wifi0 -s "NickConnect" -p "testpass"(from console), while connected toNickHotspot, got:
Targeted WiFi device: wifi0
Access points: ["NickHotspot", "DIRECT-4i-BRAVIA", "Tintin", "Arenas", "WIFIDDF16F", "tl6531a0-EXT", "", "Tintin-5G"]
Starting access point...
SSH session disconnected
SSH reconnecting...
Spawning shell...
- Checked dmesg
# Dmesg output
[ 1607.898247] IPv6: ADDRCONF(NETDEV_UP): wifi0: link is not ready
[ 1607.955485] down interface wifi0
[ 1607.985486] IPv6: ADDRCONF(NETDEV_UP): wifi0: link is not ready
[ 1609.593209] In ieee80211_ioctl_set80211 3833 : returnin EOPNOTSUPP
[ 1609.598055] Failed to set Operation mode obm_cfg_start_ap Line 1033
[ 1609.599340] In ieee80211_ioctl_set80211 3833 : returnin EOPNOTSUPP
[ 1634.049666] IPv6: ADDRCONF(NETDEV_UP): wifi0: link is not ready
[ 1634.062911] down interface wifi0
[ 1634.100800] IPv6: ADDRCONF(NETDEV_UP): wifi0: link is not ready
[ 1635.606108] onebox_ioctl: 1003 Error: WLAN firmware is not active
[ 1635.748122] VAP = NULL
[ 1635.859532] onebox_cfg80211_connect:[42:c7:f1:be:15:ec]
[ 1636.076763] onebox_disconnect
[ 1636.076958] wlan_remove: Below are WLAN STATS:
[ 1636.076972] total beacon send : 0
[ 1636.076982] total beacon Interrupts Received : 0
[ 1636.076992] total_mgmt_pkt_send : 208
[ 1636.077002] total_mgmt_rx : 3794
[ 1636.077013] total_onair_mgmt : 0
[ 1636.077023] total_data_rx : 1144
[ 1636.077032] BUFFER FULL COUNTER : 0
[ 1636.077042] BUFFER SEMI FULL COUNTER : 0
[ 1636.077051] MGMT BUFFER FULL COUNTER : 0
[ 1636.078565] down interface wifi0
[ 1636.345195] onebox_disconnect:Below are the sdio stats
[ 1636.345236] total sdio Interrupts recvd : 4786
[ 1636.345248] total sdio Interrupts with zero status recvd : 4786
[ 1636.345258] total sdio buffer Interrupts recvd : 2
[ 1636.345269] total data pending Interrupts recvd : 4910
[ 1636.345279] total sdio Unkown Interrupts recvd : 0
[ 1636.345318] onebox_sdio_master_access_msword: fail to access MASTER_ACCESS_MSBYTE
[ 1636.345328] reset_chip: Unable to set ms word to common reg
[ 1636.495108] onebox_reset_card: CMD0 failed : -123
[ 1636.495525] mmc1: card fffd removed
[ 1636.551847] mmc1: new high speed SDIO card at address fffd
[ 1636.565470] will be ignored
[ 1636.678101] MAC Address : 88 da 1a 82 e8 5c
[ 1636.678154] MFG SW Version : 4.3
[ 1636.678154] Bootloader Ver : 18
[ 1636.678154] Onboard Antenna : 1
[ 1636.678154] Module Type : 0 Non-HPM
[ 1636.678154] Band Support : Dual Band
[ 1636.678154] Country domain : 0
[ 1638.034554] core_net80211_attach: macaddr 88:da:1a:82:e8:5c
[ 1638.035574] [onebox_update_country][1722] : Updating Country to 00 from WR!!!
[ 1638.129461] created vap: wifi0
[ 1638.228294] IPv6: ADDRCONF(NETDEV_UP): wifi0: link is not ready
[ 1638.232510] Disabling power save
[ 1638.243690] down interface wifi0
[ 1638.460339] IPv6: ADDRCONF(NETDEV_UP): wifi0: link is not ready
[ 1640.034584] onebox_cfg80211_connect:[42:c7:f1:be:15:ec]
[ 1640.091092] IPv6: ADDRCONF(NETDEV_CHANGE): wifi0: link becomes ready
Any other debugging info I could provide? Trying to figure out next steps.
Can you please enable persistent via the device dashboard configuration variables? This will persist the device journal logs in case you need to reboot your device. Then after you run WiFi Connect and the access point is not started can you please grab all journalctl from the host OS and attach them here? You can grab those by opening a host OS terminal and run
