WiFi antenna switch
Which way should the tiny switch near the WiFi chip be set to use the onboard antenna vs. an external antenna?
It seems that the Troubleshooting page says the opposite of the datasheet. Which one is correct?
Hi @zestyping ! the answer is OFF position for internal antenna. Thanks for pointing out the issue, We updated datasheet earlier today addressing the error https://github.com/balena-io/balena-fin/blob/master/documentation/DOCUMENTATION.md
