I’m trying to migrate from BalenaCloud to OpenBalena.
In BalenaCloud, my fleet has a configuration that can be accessed in the tab named “configuration”. There are important options here such as the DT overlays for the devices.
I am trying to recreate the same thing in OpenBalena, but the balena config command can only be applied to an image file (or a flashed storage medium?), not to the fleet on the server directly.
But if that is the correct way to do this with OpenBalena, I cannot find how to specify the DT overlays (or any other configuration option) for the image. What keys should I put in the JSON file or in the balena config write command?
Any help would be appreciated, thanks!
