I currently have a device setup in a balena fleet, (generic x64 (legacy) running within Virtualbox)
I have successfully pushed 2 releases, one using the “Deploy with balena” button, and they appear to be successful but they never deploy to the device,
Hello @kingy welcome to the balena Community! Do you still have this problem? Apologizes for replying late.
Do you see this in the logs? Applying boot config: {}? or something different? Could you please share the logs?
If this is the case, that means that there is a different local config from the cloud configuration. Is there any of your services modifying a configuration file directly?
