I am trying to get Video encoder/decoder to work with Gstreamer in container on Jetson TX2. I have installed Gstreamer following their documents,
add-apt-repository universe
add-apt-repository multiverse
apt-get update
apt-get install gstreamer1.0-tools gstreamer1.0-alsa gstreamer1.0-
plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly gstreamer1.0-libav
apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-
dev libgstreamer-plugins-good1.0-dev libgstreamer-plugins-bad1.0-dev
Gstreamer with h.264 encoder works fine on CPU,
gst-launch-1.0 videotestsrc ! 'video/x-raw, format=(string)I420,width=(int)640, height=(int)480' ! x264enc ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! qtmux ! filesink location=test.mp4 -e
however, on HW accelerator it doesn’t work,
gst-launch-1.0 videotestsrc ! 'video/x-raw, format=(string)I420,width=(int)640, height=(int)480' ! omxh264enc ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! qtmux ! filesink location=test.mp4 -e
WARNING: erroneous pipeline: no element "omxh264enc"
The libgstomx.so is installed on /usr/lib/aarch64-linux-gnu/gstreamer-1.0 but gstreamer cannot use gst-omx and the following command returns nothing,
gst-inspect-1.0 | grep omx
Does anyone know how to enable video accelerators on Jetson tx2?
Hi there @Farzad . I haven’t tried this myself, could you link to the document/tutorial you have been following. I would also maybe try install the packages for gstreamer we have in this tx2 sample project: https://github.com/balena-io-playground/tx2-sample-app/blob/master/Dockerfile#L101
Hi @shaunmulligan , I tried the sample project. It had some error and I added the libraries and packages into my dockefile. Gstreamer still does not work with HW accelerators and gst-inspect returns the following error,
root@test:/#gst-inspect-1.0 --version
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideocuda.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstgtksink.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:190): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopengl.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
gst-inspect-1.0 version 1.8.3
GStreamer 1.8.3
Could you try installing libdrm2 explicitly? I would have thought this would be brought in with the other packages, but it seems like there can be versioning issues too: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=879508
Farzad
May 14, 2019, 12:08am
12
Hi Cameron,
Thanks for suggestion but it didn’t fix the issue. I am not sure if the following dmesg logs are helpful,
[ 2358.533609] gst-plugin-scan[5588]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x83000006
[ 2358.543211] pgd = ffffffc1e067d000
[ 2358.546626] [00000000] *pgd=0000000259a1a003, *pud=0000000259a1a003, *pmd=0000000000000000
[ 2358.556442] CPU: 3 PID: 5588 Comm: gst-plugin-scan Not tainted 4.4.38-l4t-r28.2+g174510d #2
[ 2358.564792] Hardware name: quill (DT)
[ 2358.568461] task: ffffffc1e4daf080 ti: ffffffc101d14000 task.ti: ffffffc101d14000
[ 2358.575948] PC is at 0x0
[ 2358.578487] LR is at 0x7fa6079b60
[ 2358.581810] pc : [<0000000000000000>] lr : [<0000007fa6079b60>] pstate: 00000000
[ 2358.589204] sp : 0000007fdb439640
[ 2358.592524] x29: 0000007fdb439640 x28: 0000000000000001
[ 2358.597860] x27: 0000000000000093 x26: 0000000000000093
[ 2358.603193] x25: 0000000000000000 x24: 0000000000000001
[ 2358.608543] x23: 0000007fa320c878 x22: 0000007fdb43a4a0
[ 2358.613878] x21: 0000007fdb43a488 x20: 0000000000000002
[ 2358.619212] x19: 0000000000000001 x18: 000000000044fcc0
[ 2358.624554] x17: 0000007fa5d2fa40 x16: 0000007fa10f6528
[ 2358.629885] x15: 0000000000000061 x14: 0000000000000075
[ 2358.635219] x13: 000000000000006c x12: 0000000000000077
[ 2358.640559] x11: 0000000000000000 x10: 0101010101010101
[ 2358.645892] x9 : 0000000000000042 x8 : 0000000000000060
[ 2358.651225] x7 : 0000007fa10d9ee4 x6 : 000000000000002f
[ 2358.656573] x5 : 0000000000500f00 x4 : 0000000000000000
[ 2358.661911] x3 : 0000007fa30e1dc0 x2 : 0000007fdb43a4a0
[ 2358.667244] x1 : 0000007fdb43a488 x0 : 0000000000000002
[ 2358.674083] Library at 0x7fa6079b60: 0x7fa606c000 /lib/aarch64-linux-gnu/ld-2.23.so
[ 2358.681739] vdso base = 0x7fa6097000
The problem here appears to be that your libdrm library has a versioning mismatch than is expected, and doesn’t provide drmGetDevice2 - can you try running ldd /usr/lib/aarch64-linux-gnu/libgbm.so.1 | grep -i drm from inside the container, and it might reveal something helpful.
Farzad
May 14, 2019, 8:48pm
15
Hi @CameronDiver
root@3d6c4a4:/# ldd /usr/lib/aarch64-linux-gnu/libgbm.so.1 | grep -i drm
libdrm.so.2 => /usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2 (0x0000007f87e77000)
Please let me know if you need any more information. I can also grant support access if you want.
Thanks for getting back to us, it’s always good to enable support access if you could, then when @camerondiver or @shaunmulligan come online again they’ll hopefully be able to take a look.
Farzad
May 15, 2019, 4:12pm
18
Hi @chrisys ,
Thanks for your support. The support access is enabled on here is the uuid,
3d6c4a4b6789d98de25d25c788654990
zrzka
May 15, 2019, 4:22pm
20
Thanks, looking at the device now.
zrzka
May 15, 2019, 6:40pm
22
Still no luck, checked your device and it seems that there’s really some versioning mismatch. Some libs are used from the /usr/lib/aarch64-linux-gnu/ folder, some libs are used from the /usr/lib/aarch64-linux-gnu/tegra folder, etc. Now your device is offline. I started to reproducing it on my device, but didn’t finish yet. I’ll let you know.
Farzad
May 15, 2019, 6:49pm
23
oh sorry about that! I forgot to tell the team to not touch the device :))
It is online now!
Thank you
Farzad
May 22, 2019, 10:06pm
29
Hi @zrzka ,
were you able to reproduce the issue on your device?
zrzka
May 23, 2019, 10:26am
30
Hi @Farzad ,
not yet, I’m sorry. I have a week off (sick wife, taking care of a child) and will have a chance to look at it by the end of the next week.
Farzad
May 23, 2019, 4:13pm
31
Hi @zrzka ,
Sorry to hear that. I hope everything goes well on your side.
zrzka
May 30, 2019, 1:19pm
40
Hi @Farzad ,
I was able to reproduce your issue. I followed all steps of the tx2-sample-app project and got the same issue. Slightly different, but basically the same one.
root@cbc6fcb9e49a:/# LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/tegra gst-inspect-1.0 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so
(gst-inspect-1.0:7481): GStreamer-WARNING **: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so': /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice
Could not load plugin file: Opening module failed: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice
There’s something fishy with these libraries. I’ll continue with my investigation on Monday morning.
zrzka
June 3, 2019, 10:50am
42
Hi @Farzad ,
spent some time on this issue today, but still no luck. Except the fact that I run out of space on the device and had to delete lot of stuff.
Hi @Farzad ,
This problem needs deeper investigation from our site. I forwarded the problem to our devices team, which will look into this. They will update this thread once they find more information.
Hi @Farzad ,
I did some searching on the nvidia forums and put together a Dockerfile which builds gstomx from sources for L4T 28.2: Dockerfile.gstomx
If gstomx is built from sources gstreamer is able to load those elements and use them:
omx: nvoverlaysink: OpenMax Video Sink
omx: omxvp9enc: OpenMAX VP9 Video Encoder
omx: omxvp8enc: OpenMAX VP8 Video Encoder
omx: omxh265enc: OpenMAX H.265 Video Encoder
omx: omxh264enc: OpenMAX H.264 Video Encoder
omx: omxh265dec: OpenMAX H.265 Video Decoder
omx: omxh264dec: OpenMAX H.264 Video Decoder
omx: omxmpeg4videodec: OpenMAX MPEG4 Video Decoder
Using nvoverlaysink I can also see video on HDMI:
root@90ea535:/# gst-launch-1.0 videotestsrc ! 'video/x-raw, format=(string)I420,width=(int)640, height=(int)480' ! omxh264enc ! 'video/x-h264, stream-format=(string)byte-stream' ! h264parse ! omxh264dec ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
===== MSENC blits (mode: 1) into tiled surfaces =====
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 1179: BeginSequence 640x480, bVPR = 0
TVMR: LowCorner Frequency = 100000
TVMR: cbBeginSequence: 1529: DecodeBuffers = 17, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1600: Display Resolution : (640x480)
TVMR: cbBeginSequence: 1601: Display Aspect Ratio : (640x480)
TVMR: cbBeginSequence: 1669: ColorFormat : 5
TVMR: cbBeginSequence:1683 ColorSpace = NvColorSpace_YCbCr601
TVMR: cbBeginSequence: 1809: SurfaceLayout = 3
TVMR: cbBeginSequence: 1902: NumOfSurfaces = 24, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 1904: BeginSequence ColorPrimaries = 2, TransferCharacteristics = 2, MatrixCoefficients = 2
Allocating new output: 640x480 (x 24), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3464: Send OMX_EventPortSettingsChanged : nFrameWidth = 640, nFrameHeight = 480
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
TVMR: FrameRate = 30
TVMR: NVDEC LowCorner Freq = (100000 * 1024)
With this I can also see MSENC and NVDEC hw encoding/decoding engines kicking in.
