i fixed a quick libcuda.so symlink error, but running the docker results in shared object errors.
output:
root@6e55ff8c0631:/# X &
[1] 528
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-124-generic aarch64 Ubuntu
Current Operating System: Linux 6e55ff8c0631 4.9.140-tegra #1 SMP PREEMPT Fri Oct 16 12:32:46 PDT 2020 aarch64
Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Build Date: 30 November 2020 08:05:15PM
xorg-server 2:1.19.6-1ubuntu4.8 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Jan 13 12:56:05 2021
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
root@2fe2055a9ef8:/# export DISPLAY=:0
root@2fe2055a9ef8:/# gst-inspect-1.0 nvvidconv
libEGL warning: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
nvbuf_utils: Could not get EGL display connection
(gst-plugin-scanner:20): GStreamer-WARNING **: 12:41:49.464: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so': libnvidia-fatbinaryloader.so.440.18: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20): GStreamer-WARNING **: 12:41:49.468: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideocuda.so': libnvidia-fatbinaryloader.so.440.18: cannot open shared object file: No such file or directory
libEGL warning: DRI2: failed to authenticate
Factory Details:
Rank primary (256)
Long-name NvVidConv Plugin
Klass Filter/Converter/Video/Scaler
Description Converts video from one colorspace to another & Resizes
Author amit pandya <apandya@nvidia.com>
Plugin Details:
Name nvvidconv
Description video Colorspace conversion & scaler
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so
Version 1.2.3
License Proprietary
Source module gstreamer-nvvconv-plugin
Binary package GStreamer nvvconv Plugin
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseTransform
+----Gstnvvconv
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
format: { (string)I420, (string)I420_10LE, (string)P010_10LE, (string)I420_12LE, (string)UYVY, (string)YUY2, (string)YVYU, (string)NV12, (string)NV16, (string)NV24, (string)GRAY8, (string)BGRx, (string)RGBA }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-raw
format: { (string)I420, (string)UYVY, (string)YUY2, (string)YVYU, (string)NV12, (string)NV16, (string)NV24, (string)P010_10LE, (string)GRAY8, (string)BGRx, (string)RGBA }
SRC template: 'src'
Capabilities:
format: { (string)I420, (string)I420_10LE, (string)P010_10LE, (string)UYVY, (string)YUY2, (string)YVYU, (string)NV12, (string)NV16, (string)NV24, (string)GRAY8, (string)BGRx, (string)RGBA }
video/x-raw
format: { (string)I420, (string)UYVY, (string)YUY2, (string)YVYU, (string)NV12, (string)NV16, (string)NV24, (string)GRAY8, (string)BGRx, (string)RGBA }
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvvconv0"
parent : The parent of the object
Object of type "GstObject"
qos : Handle Quality-of-Service events
Boolean. Default: false
silent : Produce verbose output ?
flip-method : video flip methods
flags: readable, writable, controllable
Enum "GstNvVideoFlipMethod" Default: 0, "none"
(0): none - Identity (no rotation)
(1): counterclockwise - Rotate counter-clockwise 90 degrees
(2): rotate-180 - Rotate 180 degrees
(3): clockwise - Rotate clockwise 90 degrees
(4): horizontal-flip - Flip horizontally
(5): upper-right-diagonal - Flip across upper right/lower left diagonal
(6): vertical-flip - Flip vertically
(7): upper-left-diagonal - Flip across upper left/lower right diagonal
output-buffers : number of output buffers
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Unsigned Integer. Range: 1 - 4294967295 Default: 4
interpolation-method: Set interpolation methods
Enum "GstInterpolationMethod" Default: 0, "Nearest"
(0): Nearest - Nearest
(1): Bilinear - Bilinear
(2): 5-Tap - 5-Tap
(3): 10-Tap - 10-Tap
(4): Smart - Smart, this is default
(5): Nicest - Nicest
left : Pixels to crop at left
Integer. Range: 0 - 2147483647 Default: 0
right : Pixels to crop at right
top : Pixels to crop at top
bottom : Pixels to crop at bottom
dockerfile:
FROM balenalib/jetson-nano-ubuntu:bionic
ENV DEBIAN_FRONTEND noninteractive
RUN echo 'install L4T BPS binaries' &&\
apt-get update && apt-get install -y wget tar lbzip2 python3 libegl1 && \
wget https://developer.nvidia.com/embedded/L4T/r32_Release_v4.2/t210ref_release_aarch64/Tegra210_Linux_R32.4.2_aarch64.tbz2 && \
tar xf Tegra210_Linux_R32.4.2_aarch64.tbz2 && \
cd Linux_for_Tegra &&\
sed -i 's/config.tbz2\"/config.tbz2\" --exclude=etc\/hosts --exclude=etc\/hostname/g' apply_binaries.sh && \
sed -i 's/install --owner=root --group=root \"${QEMU_BIN}\" \"${L4T_ROOTFS_DIR}\/usr\/bin\/\"/#install --owner=root --group=root \"${QEMU_BIN}\" \"${L4T_ROOTFS_DIR}\/usr\/bin\/\"/g' nv_tegra/nv-apply-debs.sh && \
sed -i 's/LC_ALL=C chroot . mount -t proc none \/proc/ /g' nv_tegra/nv-apply-debs.sh && \
sed -i 's/umount ${L4T_ROOTFS_DIR}\/proc/ /g' nv_tegra/nv-apply-debs.sh && \
sed -i 's/chroot . \// /g' nv_tegra/nv-apply-debs.sh && \
./apply_binaries.sh -r / --target-overlay && cd .. && \
rm -rf Tegra210_Linux_R32.4.2_aarch64.tbz2 && \
rm -rf Linux_for_Tegra && \
echo “/usr/lib/aarch64-linux-gnu/tegra” > /etc/ld.so.conf.d/nvidia-tegra.conf && ldconfig
RUN echo 'install X11 display' &&\
apt-get install -y --no-install-recommends \
xserver-xorg-input-evdev \
xinit \
xfce4 \
xfce4-terminal \
x11-xserver-utils \
dbus-x11 \
xterm
ENV LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/tegra
ENV UDEV=1
RUN echo 'prevent display turning off' &&\
echo “#!/bin/bash” > /etc/X11/xinit/xserverrc &&\
echo “” >> /etc/X11/xinit/xserverrc &&\
echo ‘exec /usr/bin/X -s 0 dpms’ >> /etc/X11/xinit/xserverrc
RUN echo 'fix symlink' &&\
ln -s /usr/lib/aarch64-linux-gnu/libcuda.so /usr/lib/aarch64-linux-gnu/libcuda.so.1 &&\
ldconfig
RUN echo 'install gstreamer tools' &&\
apt-get -y install --reinstall libgstreamer1.0-0 gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-doc \
gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl \
gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio \
gobject-introspection gir1.2-gst-rtsp-server-1.0 && \
ldconfig
ENTRYPOINT ["/bin/bash"]
