There doesn’t appear to be anywhere to download updates and the software is connected to WiFi but doesn’t check for new updates? From reading around it sounds like there is a newer version available by quite a bit. What do I need to do?
Hi, the EtcherPro is maintained via the EtcherPro-Fleet.
Checking the repository, the latest version of Etcher supported by EtcherPro is 1.14.3, so your device is running the latest compatible version.
Is there a specific problem you are having that you are trying to address with an update?
Thanks for the reply. Looks like I may have been mixing up versions with Belena OS. We were able to work around some issues but in general it has just been on the slow side which causes a lot of problems with button press selection. Going to try a different source USB drive and replacing the fan that is making a lot of noise.
Feel free to list the issues that you have with your Etcher Pro and we can try to connect you with the Etcher Pro team to solve your problems or even replace your device, if needed.
