If it helps at all I am following this tutorial on configuring Pi-hole. I’ve been successful all the way up to step 4. I added the TZ environment variable but after that I ran into this issue. Any help would be greatly appreciated! Also the button is also greyed out at the “fleet” level config page.
This is likely to be because there is no release pushed to the application (and by extension no service to attach the variable to).
Can you ensure that you first push the application and then assign them? We will probably restructure that tutorial a little to avoid this situation in the future.
To push the code, follow the step i the tutorial named “Deploying the software”.
I will be going to my schools hackerspace to retry the project in a couple of hours. I will let you know if I am successful or not. Really looking forward to getting this project up and running.
