Unable to add new device and flash Etcher 1.19.25
Error: (0 , h.requestMetadata) is not a function
Mac x64
Was able to flash on a newer Mac with arm64 but the rpi4 would not connect
Tried multiple versions of BalenaOS with both Macs, same behavior for both.
This is a permision Issue and for MacOS you need to touch the terminal to open as “sudo” or administrator
Steps:
  1. Go to “Terminal” app and open it
  2. Change the folder to Applications whit this command:
cd /Applications
  1. Type this command to open as administrator:
sudo open balenaEtcher.app/
  1. Finally you to type you’r password account, they should be like:
password:
