Hi everyone!
I have successfully running a Resin Image on my Jetson Tx2. I want to run it in max power mode. I tried the following using raw Ubuntu on the Jetson and it worked, but when I tried that within Resin it failed.
To change the mode I executed
nvpmodel -m 2
And to turn on the fan I executed this script that was part of the Jetpack configs files.
In resin I got
./jetson_cores.sh: line 208: /sys/kernel/debug/tegra_cpufreq/M_CLUSTER/cc3/enable: No such file or directory
./jetson_cores.sh: line 209: /sys/kernel/debug/tegra_cpufreq/B_CLUSTER/cc3/enable: No such file or directory
./jetson_cores.sh: line 301: /sys/kernel/debug/bpmp/debug/clk/emc/rate: No such file or directory
./jetson_cores.sh: line 307: /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked: No such file or directory
Can't access Fan!
How can I then have access to those low level features within Resin?
Thanks in advance!
