So, i’m making a bootable sd card and then inserting it into the jetson, turning it off, and then back on to attempt to reprovision it, and nothing happens, it kinda just sits there with all the lights turned of forever… i’m kind of at a loss as to what’s going on? Is the flash memory on the Jetson corrupt?
Also i should mention i’m trying to overwrite an old version of resin on the board already, if i take the SD card out it boots just fine to the OLD resin w/ the app running etc.
Errrr sorry i’m kindof a noobie at this, by serial console you mean taking a look at the output as it tries to boot? If so i’ve tried looking at the HDMI output but nothing shows up after i turn the power on. If not, could you elaborate a bit more?
Hi sometimes a fresh jetson is not be able to get resin os installed, what I usually do is flash the last jetpack and flashing the os only, and then using resin image afterwards.
Yes, for every TX2 that hasn’t been flashed with resinOS before, we would recommend flashing the latest Jetpack before attempting to flash resinOS. Many boards ship from the factory with old bootloader that is just not capable of a lot of things.
Hey all, so I just got the necessary cable and i’m going to give a look see as to what’s going on, curious thing is that the board DOES have a resin OS on it already, i’m trying to upgrade it essentially. I’ll post back once i get the console working etc
This is an enormous bummer, it defeats the purpose of balena’s amazing process for flashing devices. Is there any way around this? Jetpack is a pain in the ass.
