Hey guys, I am trying to install the Balena Python SDK in my device image (for controlling some Balena functions from within the device), but having trouble.
Even if I create the smallest docker file possible:
FROM balenalib/%%BALENA_MACHINE_NAME%%-python:2.7
WORKDIR /usr/src/app
ENV INITSYSTEM on
RUN apt-get clean && apt-get update && apt-get install -yq \
gcc \
RUN pip install balena-sdk
It won’t build. I get the error:
[main] Step 5/6 : RUN pip install balena-sdk
[main] ---> Running in 8ae5d051946a
[main] DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
[main]
[main] Collecting balena-sdk
[main] Downloading https://files.pythonhosted.org/packages/42/61/7b8431dfe4156789529320595c2ff98de6bd45a5118834baeec34d91f53e/balena-sdk-7.7.0.zip (52kB)
[main] Collecting PyJWT>=1.5.0 (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/87/8b/6a9f14b5f781697e51259d81657e6048fd31a113229cf346880bb7545565/PyJWT-1.7.1-py2.py3-none-any.whl
[main] Collecting requests>=2.19.1 (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/7d/e3/20f3d364d6c8e5d2353c72a67778eb189176f08e873c9900e10c0287b84b/requests-2.21.0-py2.py3-none-any.whl (57kB)
[main] Collecting pyotp>=2.2.5 (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/8d/3b/523e8fbe65fc71294b98d84832577cdb4610b2aaee9ddbd8ee571a562895/pyotp-2.2.7-py2.py3-none-any.whl
[main] Collecting pyOpenSSL==18.0.0 (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/96/af/9d29e6bd40823061aea2e0574ccb2fcf72bfd6130ce53d32773ec375458c/pyOpenSSL-18.0.0-py2.py3-none-any.whl (53kB)
[main] Collecting Twisted>=18.7.0 (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/f8/2b/a80a70f71eb2b86992ffa5aaae41457791ae67faa70927fd16b76127c2b7/Twisted-19.2.0.tar.bz2 (3.1MB)
[main] Collecting service-identity (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/e9/7c/2195b890023e098f9618d43ebc337d83c8b38d414326685339eb024db2f6/service_identity-18.1.0-py2.py3-none-any.whl
[main] Collecting semver (from balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/21/18/a0de8cda637ba3efee1b3617ded00601507ce15bd70a39399740e0fd415f/semver-2.8.1-py2.py3-none-any.whl
[main] Collecting certifi>=2017.4.17 (from requests>=2.19.1->balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/60/75/f692a584e85b7eaba0e03827b3d51f45f571c2e793dd731e598828d380aa/certifi-2019.3.9-py2.py3-none-any.whl (158kB)
[main] Collecting idna<2.9,>=2.5 (from requests>=2.19.1->balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/14/2c/cd551d81dbe15200be1cf41cd03869a46fe7226e7450af7a6545bfc474c9/idna-2.8-py2.py3-none-any.whl (58kB)
[main] Collecting chardet<3.1.0,>=3.0.2 (from requests>=2.19.1->balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl (133kB)
[main] Collecting urllib3<1.25,>=1.21.1 (from requests>=2.19.1->balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/df/1c/59cca3abf96f991f2ec3131a4ffe72ae3d9ea1f5894abe8a9c5e3c77cfee/urllib3-1.24.2-py2.py3-none-any.whl (131kB)
[main] Collecting six>=1.5.2 (from pyOpenSSL==18.0.0->balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/73/fb/00a976f728d0d1fecfe898238ce23f502a721c0ac0ecfedb80e0d88c64e9/six-1.12.0-py2.py3-none-any.whl
[main] Collecting cryptography>=2.2.1 (from pyOpenSSL==18.0.0->balena-sdk)
[main] Downloading https://files.pythonhosted.org/packages/07/ca/bc827c5e55918ad223d59d299fff92f3563476c3b00d0a9157d9c0217449/cryptography-2.6.1.tar.gz (491kB)
[main] Installing build dependencies: started
[main] Installing build dependencies: finished with status 'error'
[main] Complete output from command /usr/local/bin/python /usr/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-HbIt0b/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools>=18.5 wheel "cffi>=1.8,!=1.11.3; python_implementation != 'PyPy'":
[main] Collecting setuptools>=18.5
[main] Downloading https://files.pythonhosted.org/packages/ec/51/f45cea425fd5cb0b0380f5b0f048ebc1da5b417e48d304838c02d6288a1e/setuptools-41.0.1-py2.py3-none-any.whl (575kB)
[main] Collecting wheel
[main] Downloading https://files.pythonhosted.org/packages/96/ba/a4702cbb6a3a485239fbe9525443446203f00771af9ac000fa3ef2788201/wheel-0.33.1-py2.py3-none-any.whl
[main] Collecting cffi!=1.11.3,>=1.8
[main] Downloading https://files.pythonhosted.org/packages/93/1a/ab8c62b5838722f29f3daffcc8d4bd61844aa9b5f437341cc890ceee483b/cffi-1.12.3.tar.gz (456kB)
[main] Collecting pycparser (from cffi!=1.11.3,>=1.8)
[main] Downloading https://files.pythonhosted.org/packages/68/9e/49196946aee219aead1290e00d1e7fdeab8567783e83e1b9ab5585e6206a/pycparser-2.19.tar.gz (158kB)
[main] Building wheels for collected packages: cffi, pycparser
[main] Building wheel for cffi (setup.py): started
[main] Building wheel for cffi (setup.py): finished with status 'error'
[main] Complete output from command /usr/local/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-YUSu9l/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-gdsHPy --python-tag cp27:
[main] /usr/bin/ld: cannot find crt1.o: No such file or directory
[main] /usr/bin/ld: cannot find crti.o: No such file or directory
[main] collect2: error: ld returned 1 exit status
[main] Note: will not use '__sync_synchronize()' in the C code
[main] ***** The above error message can be safely ignored.
[main] running bdist_wheel
[main] running build
[main] running build_py
[main] creating build
[main] creating build/lib.linux-armv7l-2.7
[main] creating build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/cparser.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/pkgconfig.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/commontypes.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/vengine_gen.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/recompiler.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/api.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/error.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/model.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/ffiplatform.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/lock.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/__init__.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/verifier.py -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/_cffi_include.h -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/parse_c_type.h -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/_embedding.h -> build/lib.linux-armv7l-2.7/cffi
[main] copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-2.7/cffi
[main] running build_ext
[main] building '_cffi_backend' extension
[main] creating build/temp.linux-armv7l-2.7
[main] creating build/temp.linux-armv7l-2.7/c
[main] gcc -pthread -fno-strict-aliasing -g -O2 -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DUSE__THREAD -I/usr/include/ffi -I/usr/include/libffi -I/usr/local/include/python2.7 -c c/_cffi_backend.c -o build/temp.linux-armv7l-2.7/c/_cffi_backend.o
[main] In file included from /usr/lib/gcc/arm-linux-gnueabihf/6/include-fixed/syslimits.h:7:0,
[main] from /usr/lib/gcc/arm-linux-gnueabihf/6/include-fixed/limits.h:34,
[main] from /usr/local/include/python2.7/Python.h:19,
[main] from c/_cffi_backend.c:2:
[main] /usr/lib/gcc/arm-linux-gnueabihf/6/include-fixed/limits.h:168:61: fatal error: limits.h: No such file or directory
[main] #include_next <limits.h> /* recurse down to the real one */
[main] ^
[main] compilation terminated.
[main] error: command 'gcc' failed with exit status 1
[main] ----------------------------------------
[main] Failed building wheel for cffi
[main] Running setup.py clean for cffi
[main] Building wheel for pycparser (setup.py): started
[main] Building wheel for pycparser (setup.py): finished with status 'done'
[main] Stored in directory: /root/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511
[main] Successfully built pycparser
[main] Failed to build cffi
[main] Installing collected packages: setuptools, wheel, pycparser, cffi
[main] Running setup.py install for cffi: started
[main] Running setup.py install for cffi: finished with status 'error'
[main] Complete output from command /usr/local/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-YUSu9l/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-W2JFDT/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-HbIt0b/overlay --compile:
[main] running install
[main] ^
[main] Command "/usr/local/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-YUSu9l/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-W2JFDT/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-HbIt0b/overlay --compile" failed with error code 1 in /tmp/pip-install-YUSu9l/cffi/
[main] You are using pip version 19.0.1, however version 19.0.3 is available.
[main] You should consider upgrading via the 'pip install --upgrade pip' command.
[main] Command "/usr/local/bin/python /usr/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-HbIt0b/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools>=18.5 wheel "cffi>=1.8,!=1.11.3; python_implementation != 'PyPy'"" failed with error code 1 in None
[main]
[main]
[main] Removing intermediate container 8ae5d051946a
[Info] Uploading images
[main] The command '/bin/sh -c pip install balena-sdk' returned a non-zero code: 1
[Error] Service: main
[Error] Error: The command '/bin/sh -c pip install balena-sdk' returned a non-zero code: 1
Any idea’s?
