When trying to install the balena-SDK with:
RUN pip install pytz && pip install protobuf==3.9.0 && pip install psutil==5.6.3 && pip install balena-sdk
The following appears in the builder.
Could not find a version that satisfies the requirement cffi!=1.11.3,>=1.8 (from versions: )
[main]
[main] No matching distribution found for cffi!=1.11.3,>=1.8
Build logs here, support access granted to application.
I want to use the sdk to update a devices’s tags from that device. If this isn’t possible, I can go back to using API routes, but I would prefer not to.
-Thomas
