The balena ADS-B Thread
when click on show logs, window open in plane finder
Hi @sadeedp,
Thanks for reporting this. Can you please create an issue in our GitHub repo here? GitHub · Where software is built
@Ketil ,
done.
Thanks @sadeedp, we will follow up there.
I launched balena ads b but my fr24 feeder does not transmit any data even though it is online. I exclude the antenna and my Flightaware Pro Stick Plus because on the previous configuration everything worked.
Why this error on ADSB-EXCHANGE logs?
adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Attempting connection to feed.planespotters.net (2a01:4f8:1c17:6bfd::1) port 30004 ...
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (2a01:4f8:1c17:6bfd::1) port 30004 failed: Transport endpoint is not connected
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Attempting connection to feed.planespotters.net (2a01:4f8:c17:8a5f::1) port 30004 ...
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (2a01:4f8:c17:8a5f::1) port 30004 failed: Transport endpoint is not connected
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.radarplane.com (65.109.65.34) port 30001 timed out.
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: feed1.adsbexchange.com port 30004: Bad connection, dropping data (connection lost  2.8% of data) (suppress msg for 10 s)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Attempting connection to feed.radarplane.com (65.109.65.34) port 30001 ...
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Attempting connection to feed.planespotters.net (116.202.102.108) port 30004 ...
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3293): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Attempting connection to feed.planespotters.net (116.202.107.112) port 30004 ...
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3294): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3297): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3298): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3301): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3302): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3305): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3306): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: feed1.adsbexchange.com port 30004: Bad connection, dropping data (connection lost  2.9% of data) (suppress msg for 10 s)
 adsb-exchange  [mlat-client]    Lost connection to mlat.planespotters.net:31090
 adsb-exchange  [mlat-client]    Disconnecting from dump1090-fa:30005: Lost connection to multilateration server, no need for input data
 adsb-exchange  [mlat-client]    Connected to multilateration server at mlat.planespotters.net:31090, handshaking
 adsb-exchange  [mlat-client]    Handshake complete: Compression zlib2, UDP transport disabled, Split sync disabled
 adsb-exchange  [mlat-client]    Input connected to dump1090-fa:30005
 adsb-exchange  [mlat-client]    Input format changed to BEAST, 12MHz clock
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3309): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3310): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3313): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3314): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3317): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3318): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3321): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3322): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3325): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3326): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3329): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3330): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3333): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3334): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3337): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3338): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3341): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3342): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: feed1.adsbexchange.com port 30004: Bad connection, dropping data (connection lost  3.0% of data) (suppress msg for 10 s)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3345): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3346): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3349): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3350): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3353): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3354): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3357): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3358): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3361): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3362): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.102.108) port 30004 failed (3365): 111 (Connection refused)
 adsb-exchange  [feed-adsbx]     BeastReduce TCP output: Connection to feed.planespotters.net (116.202.107.112) port 30004 failed (3366): 111 (Connection refused)
