Deploy with balena button doesn’t work on any repos.
For example:
Or even from balenaHub:
Gives:
Error: Failed to fetch tarball from passed URL
@shawaj hello!
Actually the Deploy with balena button is currently broken due to a security fix. We are working on a solution here!
Hey dude @mpous, hope you are well!
Thanks for the quick reply. Do you have any rough idea of timeline for when it might be fixed?
I don’t know @shawaj i only know that we are working on this!
We will keep you posted!
@sadeedp that’s a separate issue altogether. You can track it here Plane watch container will not start · Issue #235 · ketilmo/balena-ads-b · GitHub
@sadeedp that should be fixed now. try again
@shawaj , yes now it working after updated with new release, btb, can i delete old releases from the device?
@sadeedp yes. I think they should auto delete but if not you can purge them yes
Same issue here!
Hi, thanks for raising this. I am seeing the same issue and have reached out to my colleagues. We’ll keep you updated as we learn more.
This seems to be fixed now ![]()
