I’m having starting success, logging into a Pi via resin.io website terminal (way cool!) and running the sample node.js express server after pushing via Git on my Mac (also way cool!).
Getting resin-cli setup on my Mac has been a challenge.
node v8.9.3
Mac High Sierra v0.13.2
rsync v2.6.9
When I run:
sudo npm install --global --production resin-cli
It fails with this output:
npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
/usr/local/bin/resin -> /usr/local/lib/node_modules/resin-cli/bin/resin
> ext2fs@0.1.1 install /usr/local/lib/node_modules/resin-cli/node_modules/ext2fs
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(undefined): https://github.com/resin-io/node-ext2fs/releases/download/v0.1.1/bindings-v0.1.1-node-v57-darwin-x64.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for ext2fs@0.1.1 and node@8.9.3 (node-v57 ABI, unknown) (falling back to source compile with node-gyp)
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/build'
gyp ERR! System Darwin 17.3.0
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/pregyp/bindings.node" "--module_name=bindings" "--module_path=/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/pregyp"
gyp ERR! cwd /usr/local/lib/node_modules/resin-cli/node_modules/ext2fs
gyp ERR! node -v v8.9.3
gyp ERR! node-gyp -v v3.6.2
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/pregyp/bindings.node --module_name=bindings --module_path=/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/pregyp' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:925:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
node-pre-gyp ERR! System Darwin 17.3.0
node-pre-gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/resin-cli/node_modules/ext2fs/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/resin-cli/node_modules/ext2fs
node-pre-gyp ERR! node -v v8.9.3
node-pre-gyp ERR! node-pre-gyp -v v0.6.39
node-pre-gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: removedrive@1.1.2 (node_modules/resin-cli/node_modules/removedrive):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for removedrive@1.1.2: wanted {"os":"win32","arch":"any"} (current: {"os":"darwin","arch":"x64"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! ext2fs@0.1.1 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the ext2fs@0.1.1 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /Users/me/.npm/_logs/2018-01-04T00_08_21_865Z-debug.log
If I download the latest darwin zip and add the path to my .profile, I can run the resin cli and even pick my device (awesome!). The challenge occurs when I attempt to sync or ssh in to a device:
resin ssh
I choose my device, then this output occurs:
Connecting to: abcde12345.....
ResinRequestError: Request error: tunneling socket could not be established, cause=socket hang up
If you need help, don't hesitate in contacting us at:
GitHub: https://github.com/resin-io/resin-cli/issues/new
Forums: https://forums.balena.io
I’m guessing I could still develop via git pushes, correct (reading up on all that now)? Let me know if you’ve run into this before and if there’s a good solution or something I can try.
Thanks for taking a look.
