There are a few supported carrier boards for NVIDIA Jetson that can work with a range of different Jetson modules. For example, the Auvidea JN30B supports both the Nano and the Xavier NX. However, only support for the Nano is listed in the Balena documentation. Does anyone have experience using modules other than the ones officially supported in Balena with carrier boards? It appears that the only option for a carrier board that supports multiple module types is the CTI Photon, which can be quite pricey.
Hi Alex, thanks for your message. Currently images are device type specific, so an image that targets a Nano module will not work for a Xavier NX. We will discuss internally whether multi-platform images that can boot with different device trees is a possibility to support this use case in the future.
