Hi @cywang117 and @klutchell,
unfortunatly, I’m facing the same situation as well. The device is a Compulab IOT-gate-iMX8 with two LAN, one wifi and one mobile network adapter. I’m running balenaOS 2.98.33 and the error was the same with supervisor version Supervisor version 13.1.11 and 14.4.8.
The core issue is, that I’m not able to push changes to the device locally:
Retrying "Supervisor API (GET http://192.168.0.130:48484/ping)" after 2.0s (1 of 5) due to: Error: connect ECONNREFUSED 192.168.0.130:48484
Looking at the lsof output, I can see that port 48484 is only available on IPV6:
root@c5d1c5a:~# lsof -iTCP -sTCP:LISTEN
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
systemd 1 root 62u IPv6 21939 0t0 TCP *:22222 (LISTEN)
dnsmasq 1398 nobody 5u IPv4 23042 0t0 TCP c5d1c5a:domain (LISTEN)
dnsmasq 1398 nobody 7u IPv4 23044 0t0 TCP c5d1c5a:domain (LISTEN)
balenad 1426 root 10u IPv6 28113 0t0 TCP *:2375 (LISTEN)
node 1964 root 21u IPv6 29709 0t0 TCP *:48484 (LISTEN)
After disabling IPV6 for eth0, following this guide, the network settings look like this:
root@c5d1c5a:~# ifconfig -a
balena0 Link encap:Ethernet HWaddr 02:42:BF:C3:DB:38
inet addr:10.114.101.1 Bcast:10.114.101.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
br-3fe834a4f816 Link encap:Ethernet HWaddr 02:42:B3:B1:51:01
inet addr:172.17.0.1 Bcast:172.17.255.255 Mask:255.255.0.0
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
collisions:0 txqueuelen:10
Interrupt:216
eth0 Link encap:Ethernet HWaddr 00:01:C0:31:DB:F2
inet addr:192.168.0.130 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:824069 errors:0 dropped:0 overruns:0 frame:0
TX packets:164288 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:190009976 (181.2 MiB) TX bytes:22892610 (21.8 MiB)
eth1 Link encap:Ethernet HWaddr 00:01:C0:32:B2:2A
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:34968 errors:0 dropped:0 overruns:0 frame:0
TX packets:34968 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5884438 (5.6 MiB) TX bytes:5884438 (5.6 MiB)
resin-dns Link encap:Ethernet HWaddr 62:B5:0C:23:9C:46
inet addr:10.114.102.1 Bcast:0.0.0.0 Mask:255.255.255.0
resin-vpn Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.241.52.37 P-t-P:52.4.252.97 Mask:255.255.255.255
inet6 addr: fe80::d214:c8be:9b27:bd5c/64 Scope:Link
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:3456 (3.3 KiB)
supervisor0 Link encap:Ethernet HWaddr 02:42:F4:0C:11:75
inet addr:10.114.104.1 Bcast:10.114.104.127 Mask:255.255.255.128
wlan0 Link encap:Ethernet HWaddr 3E:78:55:9B:21:B6
wwan0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
POINTOPOINT NOARP MULTICAST MTU:1500 Metric:1
resin-vpn seems to still use an IPV6 connection, but this is nothing I can change via nmcli. In the Balena dashboard is is showing the local IP address 192.168.0.130 only. So this looks also fine for me.
The “OS variant” is development and I’m also able to connect to the device locally via balena ssh c5d1c5a.local.
iptables output looks like this:
root@c5d1c5a:~# iptables -L BALENA-FIREWALL -v
Chain BALENA-FIREWALL (1 references)
pkts bytes target prot opt in out source destination
141K 51M ACCEPT all -- any any anywhere anywhere state RELATED,ESTABLISHED
14419 958K ACCEPT all -- any any anywhere anywhere ADDRTYPE match src-type LOCAL
0 0 ACCEPT tcp -- resin-vpn any anywhere anywhere tcp dpt:48484
0 0 ACCEPT tcp -- tun0 any anywhere anywhere tcp dpt:48484
0 0 ACCEPT tcp -- docker0 any anywhere anywhere tcp dpt:48484
0 0 ACCEPT tcp -- lo any anywhere anywhere tcp dpt:48484
0 0 ACCEPT tcp -- supervisor0 any anywhere anywhere tcp dpt:48484
4 256 REJECT tcp -- any any anywhere anywhere tcp dpt:48484 reject-with icmp-port-unreachable
5 376 ACCEPT tcp -- any any anywhere anywhere tcp dpt:22222
6 384 ACCEPT tcp -- any any anywhere anywhere tcp dpt:2375
173K 55M ACCEPT all -- any any anywhere anywhere ADDRTYPE match dst-type MULTICAST
0 0 ACCEPT icmp -- any any anywhere anywhere
0 0 ACCEPT udp -- balena0 any anywhere anywhere udp dpt:domain
56682 4153K RETURN all -- any any anywhere anywhere
0 0 REJECT all -- any any anywhere anywhere reject-with icmp-port-unreachable
Maybe it is related to this issue? After a second boot iptables output looks like this:
6 1239 ACCEPT all -- any any anywhere anywhere state RELATED,ESTABLISHED
4 264 ACCEPT all -- any any anywhere anywhere ADDRTYPE match src-type LOCAL
0 0 REJECT tcp -- any any anywhere anywhere tcp dpt:48484 reject-with icmp-port-unreachable
0 0 ACCEPT tcp -- any any anywhere anywhere tcp dpt:22222
0 0 ACCEPT tcp -- any any anywhere anywhere tcp dpt:2375
0 0 ACCEPT all -- any any anywhere anywhere ADDRTYPE match dst-type MULTICAST
0 0 RETURN all -- any any anywhere anywhere
It would be great to get the local development mode up and running, since it would speed up the development process. Could you give me any advise, maybe I should debug further?
The situation was also reproducable with the same device being newly flashed. Also enabling and disabling the “local mode” with or without a reboot was not changing this situation.
Thanks for any support.
(Edit: Added supervison and host os versions)
