Successful deploy and run, but ">_ Terminal" feature is not working
I’ve followed carefully this tutorial : https://docs.resin.io/raspberrypi/nodejs/getting-started/, and it has worked until the deployment and start of the app :
04.05.17 10:25:51 (+0200) Started application 'registry2.resin.io/testapp/ea51fe33f7cac8af562919a5e1caed75235229f6’
04.05.17 10:25:51 (+0200) Systemd init system enabled.
04.05.17 10:25:52 (+0200) systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECC
OMP -APPARMOR)
04.05.17 10:25:52 (+0200) Detected virtualization ‘other’.
04.05.17 10:25:52 (+0200) Detected architecture ‘arm’.
04.05.17 10:25:52 (+0200) Set hostname to <30467b3>.
04.05.17 10:26:31 (+0200)
04.05.17 10:26:31 (+0200) > simple-server-node@1.0.0 start /usr/src/app
04.05.17 10:26:31 (+0200) > node server.js
04.05.17 10:26:35 (+0200) Example app listening on port 80
I can access the “hello world” display here :
https://30467b33a2905eae43448bbfbf1d3720.resindevice.io/
But now, when I click on “>_ Terminal” and then on “>_ Start Terminal”, the terminal blinks and disappear at once, am I missing something ?
Now I have to say after a full reboot of my computer, I can access the device Terminal. So maybe something was pending on my computer blocking the access, I had just upgraded Avast Antivirus without reboot…
